Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2593797
12/18/18 03:23 PM
12/18/18 03:23 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Did I miss something? Not sure why you need to keep the ballast at all. Just hook it up like you would an MSD by attaching the start and run wires and get rid of the ballast--that should give you the consistent voltage you need.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: BDW] #2593910
12/18/18 07:26 PM
12/18/18 07:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By BDW
Still need to combine start and run, relays aren't small.
Yes, they are. Every new car out there used a bunch of relays to power high loads. they are not big, they are not expensive and they are not a mystery to be avoided.
Nor do you need to dance around in the nude and sacrifice a chicken to the god of electrons.
Any other objections?
This 30A automotive grade relay is 2" tall and about 1.24" square, Under $4 and includes a mounting tab.
the connector if you want one. Under $4 again.
Don't be the exception.
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2593943
12/18/18 08:25 PM
12/18/18 08:25 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
EFI doesn’t suck lot of load. We have talked about that in several threads. Take the power from the Blue run circuit and install a Diode between ballast prongs to get 12 volts on both ign positions without affect the power to coil while in RUN
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: Supercuda] #2593963
12/18/18 09:15 PM
12/18/18 09:15 PM
BDW Offline
BDW  Offline
So you're saying I can replace the 1/4" diode with a 2"x4" relay? That's great news, thx for the insight.
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2594082
12/19/18 01:58 AM
12/19/18 01:58 AM
Canada
CrAzYMoPaRGuY Offline OP
Canada
My buddy opted to run power from the ballast to a relay, and has the ECU powered from the battery- interrupted by lack of ballast resisitor power. We might run the diode. Just getting a diode isn't easy on a Sunday! wink
It's a Professional Products EFI kit, says to run direct to coil but cannot drop below 9 volts. The instructions are more confusing than the actual work! lol
This is the same ECU that had me ask a couple months ago.... "Rear wheel torque for 440"!!! It wanted a value. We ended up using 400 ft lbs.
Geez
CrAzYMoPaRGuY
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2594092
12/19/18 02:09 AM
12/19/18 02:09 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
.....‘‘tis a good nite - da Bolts spank the ‘nucks ! penguin
