Powerglide to BB Mopar Flywheel #2593120
12/17/18 01:18 PM
12/17/18 01:18 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
What SFI flywheel is needed to bolt up to a BB Mopar when you run a glide?
We plan on using the Reid 2 piece case with BB Mopar bell.
Is it just a flywheel that is needed or do we need some sort of crank adapter also?
Re: Powerglide to BB Mopar Flywheel [Re: cl440] #2593121
12/17/18 01:20 PM
12/17/18 01:20 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, you need a couple of goodies. I would call ATI and tell them to send you what you need.
2011 Drag Pak Challenger
Re: Powerglide to BB Mopar Flywheel [Re: rickseeman] #2593125
12/17/18 01:32 PM
12/17/18 01:32 PM
Kentucky
3
301v Offline
301v  Offline
Kentucky
Several different options out there and i have tried pretty well all of them and i really like the Ati adaptor kit over all the rest.
Re: Powerglide to BB Mopar Flywheel [Re: cl440] #2593291
12/17/18 06:46 PM
12/17/18 06:46 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I have both ATI and TCI adapter kits, and they use a special flywheel that already has the Mopar crank pattern on it. It is drilled for the GM converter. Both have a billet retainer ring that goes on the outside of the crank hub for the converter to rest in.
Make sure you have the converter properly centered when using the BBM bellhousing on the case. I know of some people who had troubles with the ATI setup where the converter was slightly off-center. They had to use slightly offset dowels to correct everything.
Re: Powerglide to BB Mopar Flywheel [Re: cl440] #2593597
12/18/18 04:31 AM
12/18/18 04:31 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I've run every combination out there. We currently have an ATI adapter plate in the dragster that uses a passenger side mounted starter. It works great BUT you have to have a really thin pan rail when using a stock style mini starter and you can use a commonly available kickout pan. This car uses a Reid one piece case, flexplate is an ATI with their crank hub.
The Stratus uses an ATI case with a Mopar bell. It works great as well and uses the same ATI flexplate and hub. Both use FTI converters. Only drawback to this set up is limited room to get at converter bolts. Both need the starter shimmed. IMO the easier most straight forward deal is Mopar Bell with one of the available flexplates and hub adapters. I have also use JW bell and TCI adapters.
Re: Powerglide to BB Mopar Flywheel [Re: cl440] #2593802
12/18/18 03:31 PM
12/18/18 03:31 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I use the ATI flexplate, Reid bellhousing, transmission case, and JW or BTE .250 spacer and Mopar aftermarket starter. Beware of used or for sale bellhousings as some of the first ones were off length wise. BTE is good to deal with and better than JW, as they have it figured out.
Re: Powerglide to BB Mopar Flywheel [Re: cl440] #2593848
12/18/18 04:31 PM
12/18/18 04:31 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
I have the Reid bellhousing. Just trying to gather the rest of the pieces that will work to complete the install.
JW said I need his flexplate #93010C and adapter #80013 and since I have a .090 midplate I will need the converter setup for that. the converter will also need to be made for the 10.750" bolt circle.
Sounds like I may need to shim the starter also?
I was hoping I could confirm with someone who has done it and could shoot me the part #'s I need to complete the install.
ATI told me that there setup wont work with Reid because there case/Bell is 1/2" longer
I will check with BTE also.
Re: Powerglide to BB Mopar Flywheel [Re: cl440] #2593898
12/18/18 06:29 PM
12/18/18 06:29 PM
sst404b Offline
sst404b  Offline
I just did the same thing but with small block, Reid bell and Reid glide case,with ATI converter #408800 and flywheel #915650X and JW crank adapter #80012. Needed to space starter 1/2 inch. Extended locator for starter by drilling and tapping starter nose and bolting flat washers, mid plate is .125 thick.
Re: Powerglide to BB Mopar Flywheel [Re: sst404b] #2593913
12/18/18 07:28 PM
12/18/18 07:28 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I wouldn't recommend using the JW Flexplate...Ive lost ring gear teeth on 2 of them.
I use a Meziere flex plate and Reid bell / trans case
Re: Powerglide to BB Mopar Flywheel [Re: Forest] #2593942
12/18/18 08:25 PM
12/18/18 08:25 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
iagree The price sucks but Meziere is what I used with the Reid bell/case. The starter is shimmed on mine. The flexplate also will bolt to a 6 bolt converter pattern when you make big power. With an 8 bolt crank I believe the Meziere comes with an adapter to take the starter issue away.
Re: Powerglide to BB Mopar Flywheel [Re: Forest] #2594041
12/19/18 12:34 AM
12/19/18 12:34 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I'm going on 30 years of Powerglide use in 4 different cars (big block and small block) and have never hurt a JW Flexplate. I am almost paranoid about starter installation and spend hours getting them shimmed right. Almost every combo I set up is shimmed differently some with the nose on but many I have cut the nose of the starter off. Shim kits come in VERY handy and are available at Summit.
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Powerglide to BB Mopar Flywheel [Re: pittsburghracer] #2594179
12/19/18 12:06 PM
12/19/18 12:06 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
OK good info here. I am surprised at the horror stories I have read about some guys losing sections of teeth off the ring gear.
I see JW makes a machined billet plate also. Its priced inline with Meziere.
Re: Powerglide to BB Mopar Flywheel [Re: cl440] #2594182
12/19/18 12:12 PM
12/19/18 12:12 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
We have a JW bell on our 727 and we ended up cutting the nose off the starter because the nose wouldn't fit the register in the bellhousing and I didn't want to risk grinding or doing any machining on the bell in fear that it wouldn't recert.
Re: Powerglide to BB Mopar Flywheel [Re: cl440] #2594314
12/19/18 04:40 PM
12/19/18 04:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Our dragster uses the ATI adapter plate, with their flexplate and crank hub and a one piece Reid bellhousing. The starter has NO shims and the FTI converter fits as it should. My Stratus is ALL ATI and the starter has a tad over .250" of shims. My ATI flexplate also can use a bolt converter. AS for "the wheel" broke the teeth on one once and never ran another. Cost me a final round at Phoenix Divisional from that deal. Took out the starter with it as well. I do NOT use a starter with a nose on ANY of my stuff. Like JOhn been using Mopars with a glide for a very long time.
