Re: NHRA Stock Eliminator budget friendly?
[Re: Roughbird72]
#2593328
12/17/18 07:43 PM
12/17/18 07:43 PM
Triple Threat
Renton Washington
I'm building a F/SA '68 340 Barracuda, I can confirm for you all it isn't cheap. I already own the Dually, LQ trailer and attend various divisional, national and association events throughout the year none of which will change, just the tool I bring when I go.
Anyone who thinks they want to give it a try I'd encourage to go bracket racing for awhile first. The investment is usually less, you won't need to worry about heads ups and ultimately you're going to hone the skills needed to be competitive in Stock or Super Stock, which is a glorified bracket race 95% of the time.
[Re: sixpakdodge]
#2593353
12/17/18 08:27 PM
12/17/18 08:27 PM
Posts: 20,182 Park Forest, IL
slantzilla
Park Forest, IL
As far as GM guys crying foul... let's go down the Mopar path... '62 413's with '64 heads and intake, '62-64 Max Wedge cars in any possible B-body combination you can think of, "Nascar" Hemis, trim-less hardtop Plymouths, Dodge hardtops with Sedan trim, AAR hoods on any fresh air package 1970 'Cuda, and my personal favorite...'66 Hemi cars with scoops. We probably wouldn't bring so much attention to ourselves if we didn't do such bogus things...
No to mention all the bogus "ringer" cars the factory used to throw in when everyone ran off their record...... I've been around Stock class racers of all makes for years. Every make out there has been dirty or helped by liberal rules at one time or another. The reason the eliminator became a bracket race was because of all the shenanigans going on. Bottom line is IF you want to be top dog in your class or set national records in the upper classes, budget will not be in your vocabulary. If you can be content with a car that will just qualify anywhere you can get away a lot cheaper. Then all you have to worry about is heads-up runs, and if you have chosen your class wisely you may never have one.
[Re: sixpakdodge]
#2593468
12/17/18 11:40 PM
12/17/18 11:40 PM
Posts: 4,457 Washington
madscientist
Washington
Yes you can sleeve all 8. The chevrolame guys are sleeving 454's down to 396. been going on for a decade or more.
I know of some 340 racers who were doing the same before new blocks were available. As far as GM guys crying foul... let's go down the Mopar path... '62 413's with '64 heads and intake, '62-64 Max Wedge cars in any possible B-body combination you can think of, "Nascar" Hemis, trim-less hardtop Plymouths, Dodge hardtops with Sedan trim, AAR hoods on any fresh air package 1970 'Cuda, and my personal favorite...'66 Hemi cars with scoops. We probably wouldn't bring so much attention to ourselves if we didn't do such bogus things... Really? Because for decades the factoring has killed, and I mean flat out KILLED packages and they've never been fixed. What little crumb the NHRA throws on the floor for Stock and Super Stock is just nothing compared to what GM gets. I used to follow Modified and SS religiously back in the day and stock pretty close. When NHRA killed modified I was disgusted. As I got older I still followed Stock and SS fairly close but in the last 10-15 years I haven't. So maybe the rules have changed. The last time I even looked at the rules you couldn't sleeve all 8 holes and IIRC you could only have a certain percentage of the valves with seats under them. Maybe that rule has changed as well. I think I have a 2016 rule book. I may have to thumb through it when I get home.
[Re: Triple Threat]
#2593474
12/17/18 11:49 PM
12/17/18 11:49 PM
madscientist
Washington
Anyone who thinks they want to give it a try I'd encourage to go bracket racing for awhile first. The investment is usually less, you won't need to worry about heads ups and ultimately you're going to hone the skills needed to be competitive in Stock or Super Stock, which is a glorified bracket race 95% of the time. Great car. I love that thing. Too bad it's not a stick, but then, I'm a stick guy. I tried to find the Nation record and Index for that class but I have 3 different issues of ND here and none of them have either.
[Re: Roughbird72]
#2593478
12/17/18 11:52 PM
12/17/18 11:52 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Really? Because for decades the factoring has killed, and I mean flat out KILLED packages and they've never been fixed. All you have to look at is the SS/AH class. Yeah, NHRA gave them their own class. It's certainly not factored correctly as more than half the Challenge competitors at Indy do not qualify for the SS field. Ludicrousness!
[Re: madscientist]
#2593507
12/18/18 12:19 AM
12/18/18 12:19 AM
Posts: 5,894 Florida
Locomotion
Anyone who thinks they want to give it a try I'd encourage to go bracket racing for awhile first. The investment is usually less, you won't need to worry about heads ups and ultimately you're going to hone the skills needed to be competitive in Stock or Super Stock, which is a glorified bracket race 95% of the time. Great car. I love that thing. Too bad it's not a stick, but then, I'm a stick guy. I tried to find the Nation record and Index for that class but I have 3 different issues of ND here and none of them have either. Click 1000' & 1/4 mile records. Scroll down to the bottom for Comp., SS & Stock. NHRA National Records
[Re: Triple Threat]
#2593530
12/18/18 12:56 AM
12/18/18 12:56 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Anyone who thinks they want to give it a try I'd encourage to go bracket racing for awhile first. The investment is usually less, you won't need to worry about heads ups and ultimately you're going to hone the skills needed to be competitive in Stock or Super Stock, which is a glorified bracket race 95% of the time. My neighbor Earl runs F/SA with a 68 340 FB Barracuda...Having lunch with him tomorrow..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Dave Hall]
#2593555
12/18/18 01:41 AM
12/18/18 01:41 AM
Posts: 4,101 Yes
sixpakdodge
Yes
Really? Because for decades the factoring has killed, and I mean flat out KILLED packages and they've never been fixed. All you have to look at is the SS/AH class. Yeah, NHRA gave them their own class. It's certainly not factored correctly as more than half the Challenge competitors at Indy do not qualify for the SS field. Ludicrousness! Even before the hard index, most of the Indy non-qualifiers were A-AA (before AH) cars. AH is Super Stock's version of Pro Stock. A handful of engine builders supplying the top power, with a few people following behind running yesterday's leftovers. The hard index is to encourage these guys to actually run them out. A few have asked for a 9.50 index, but there are a few cars capable of hitting that magical 1.2 under spot (8.30 on a 9.50) that would get them triggered with horsepower/weight, therefore hurting everyone. As far as the valve seat replacement, I just sold a pair of AH legal cast iron Hemi heads towards the beginning of the year that were just as they were taken off a running car a few years ago. Every seat had been replaced in those heads.
[Re: Roughbird72]
#2593570
12/18/18 02:55 AM
12/18/18 02:55 AM
slantzilla
Park Forest, IL
You also have to remember that at Indy there are a lot of really good cars that won't get in, no matter what class, especially this year when they turned off the AHFS.
[Re: Locomotion]
#2593608
12/18/18 05:28 AM
12/18/18 05:28 AM
madscientist
Washington
Thanks Myron. Do they not publish that stuff in ND any more?
[Re: madscientist]
#2593658
12/18/18 10:43 AM
12/18/18 10:43 AM
Locomotion
Thanks Myron. Do they not publish that stuff in ND any more? I haven't kept track specifically, but they have cut back a lot. Not sure how often they do publish it, if at all. It could be to save a couple of pages of print and/or perhaps there aren't as many people setting records and all of the "minimums" don't look good.
[Re: Roughbird72]
#2593720
12/18/18 12:59 PM
12/18/18 12:59 PM
Posts: 1,176 East Coast
A/MP
East Coast
A few years back, the top stock eliminator qualifier, at Indy, was a turbo PT Cruiser.
[Re: Locomotion]
#2593751
12/18/18 02:18 PM
12/18/18 02:18 PM
Posts: 8,165 Left Coast
BobR
Left Coast
That's why motorhomes and trailers with living quarters are popular with racers who travel a lot. It can save on hotel bills and travel time. But that's a big initial investment too. "IF" I can ever afford to do so, I'd like to be able to get a 42-44' gooseneck with a bathroom package and a sleeping area above the gooseneck to sleep at the track & truck stops. A small fridge and microwave would help but I always bring a BIG cooler filled with ice and food. You can still use a dually to go into town if time allows and is useful at home. I just took delivery of an Intech trailer exactly like you described. Pretty expensive piece but very cool. https://www.flyingamotorsports.com/default.asp?page=xInventoryDetail&id=5203687
[Re: Locomotion]
#2593763
12/18/18 02:46 PM
12/18/18 02:46 PM
Posts: 11,590 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Thanks Myron. Do they not publish that stuff in ND any more? I haven't kept track specifically, but they have cut back a lot. Not sure how often they do publish it, if at all. It could be to save a couple of pages of print and/or perhaps there aren't as many people setting records and all of the "minimums" don't look good. Dragster has cut back on a lot of information that was useful to the sportsman racer. Points standings, payouts and purses, contingencies, indexes and records. All that is on the NHRAracer site now. They don't even do a real story about the national event winners in the sportsman classes like they used to. Got rid of all the Dragster staff to hire a few more media experts and marketing people.
[Re: 70AARcuda]
#2593766
12/18/18 02:47 PM
12/18/18 02:47 PM
Triple Threat
Renton Washington
I bought a set of X head castings from him last year for this project.
[Re: Triple Threat]
#2593781
12/18/18 03:09 PM
12/18/18 03:09 PM
70AARcuda
las vegas
I bought a set of X head castings from him last year for this project. I sold him a set of X heads about 2 yrs ago..LOL
Tony
[Re: BobR]
#2593787
12/18/18 03:17 PM
12/18/18 03:17 PM
Locomotion
That's why motorhomes and trailers with living quarters are popular with racers who travel a lot. It can save on hotel bills and travel time. But that's a big initial investment too. "IF" I can ever afford to do so, I'd like to be able to get a 42-44' gooseneck with a bathroom package and a sleeping area above the gooseneck to sleep at the track & truck stops. A small fridge and microwave would help but I always bring a BIG cooler filled with ice and food. You can still use a dually to go into town if time allows and is useful at home. I just took delivery of an Intech trailer exactly like you described. Pretty expensive piece but very cool. https://www.flyingamotorsports.com/default.asp?page=xInventoryDetail&id=5203687 Nice. I'd take white with an escape door and could leave off a couple options to save a few bucks.
