World block oil restrictor size ? #2593360
12/17/18 08:36 PM
12/17/18 08:36 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Ok
My new world iron block wedge will be ready by Christmas luck .
What size if any oil restrictor to rocker gear would be recommended ?
The only info I came up with was 0.040" in the hemi block . This is fitted in the block feed at deck surface , so cant be changed once heads are fitted .
I will be running a solid flat tappet with Howards EDM lifters . I have Crane Gold 1.5 rockers .
Street and strip use .
TIA
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: World block oil restrictor size ? [Re: tex013] #2593394
12/17/18 10:11 PM
12/17/18 10:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
.040-.060......... pick something and go.
When I’m using the Indy external lines, I use a .060 restrictor per side with that set up....... and when I prime the motor....... there’s quite a bit of oil flowing.
Re: World block oil restrictor size ? [Re: tex013] #2593455
12/17/18 11:23 PM
12/17/18 11:23 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thanks Fast ,
Tex
New best MPH 130.32
Re: World block oil restrictor size ? [Re: tex013] #2593531
12/18/18 12:56 AM
12/18/18 12:56 AM
The 4.490 rough bore World cast iron wedge block I built several years ago had .039 restrictors in the oil passages to each head, They ended up flooding the B1 heads with single shaft roller rocker arms bad enough to cause over filling the heads issues on the dyno running the motor at 2500 RPM for extended periods while the dyno operator dinked around on the computer, both heads had two #8 AN drain back lines on both ends of the heads shock shruggy
I'm getting ready to build myself a Koleno high nickel cast iron block but I'm going to go to a set of paired shaft rocker arms EDITED on the B1-MC heads, not a single shaft set up so the oil passages to the heads won't be used twocents
Re: World block oil restrictor size ? [Re: tex013] #2593569
12/18/18 02:50 AM
12/18/18 02:50 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks Cab
Tex
New best MPH 130.32
Re: World block oil restrictor size ? [Re: Cab_Burge] #2593670
12/18/18 11:27 AM
12/18/18 11:27 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I'm getting ready to build myself a Koleno high nickel cast iron block but I'm going to go to a set of paired shaft rocker arms, not a single shaft set up so the oil passages to the heads won't be used twocents
cab
quick question, were you using a vacuum pump and was the oil return lines above the oil level in the pan?
Had the same thing happen to my B1, put clear line on the returns to test it and my engine was pulling a vacuum up the return lines. Dropped the return below oil level in the pan fixed it.
Joe
Without Data, you’re just another guy with an opinion.
Re: World block oil restrictor size ? [Re: tex013] #2593678
12/18/18 11:45 AM
12/18/18 11:45 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
I used the 'as delivered' restrictors in my mega block with a solid flat tappet. It hasn't wiped, the car works well on the street with thousands of miles, probably 15-20 drag strip passes without issues either. I'm running Indy's rocker assemblies on stock iron heads.
Re: World block oil restrictor size ? [Re: tex013] #2593735
12/18/18 01:45 PM
12/18/18 01:45 PM
So. Burlington, Vt.
So. Burlington, Vt.
That’s the kind of useful tidbit of info you store in your mind....... that may come in handy down the road.
Area wise, one .040 feed hole to each head is about the same as eight .014 size holes(as if you were pushrod oiling and restricted the feeds to .014).
Re: World block oil restrictor size ? [Re: tex013] #2593893
12/18/18 06:23 PM
12/18/18 06:23 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks again for all replies .
I think a 0.040 will be the ticket
Tex
New best MPH 130.32
Re: World block oil restrictor size ? [Re: sr4440] #2594064
12/19/18 01:15 AM
12/19/18 01:15 AM
cab
Joe
No vacuum pump on that motor then, I believe all the oil return lines where above the oil level, not below shruggy
Re: World block oil restrictor size ? [Re: tex013] #2594151
12/19/18 09:51 AM
12/19/18 09:51 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine is pushrod oil. The push rods were .090". They have been restricted with roll pins to aprox .058". Still way bigger than needed. That being said it has no issue with drain back using -1 heads. Tall rotor pump with 7.0 quarts (actual level) in the pan holds steady pressure.
Doug
Re: World block oil restrictor size ? [Re: dvw] #2594292
12/19/18 03:48 PM
12/19/18 03:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What size do you think they should be, if .058" is still too big?
Re: World block oil restrictor size ? [Re: tex013] #2594350
12/19/18 06:09 PM
12/19/18 06:09 PM
So. Burlington, Vt.
So. Burlington, Vt.
Well, let’s seeeeee....... if you can feed one whole side with a single .040 hole......
....... divided by....... carry the one...... times the square.......
Equals........ way smaller than .058 should be fine.
