Fuel pump time, recommendations please. #2592861
12/16/18 05:15 PM
12/16/18 05:15 PM
Indianapolis In. usa
Quickrunner Offline OP
Ok, getting to the plumbing and subsystems stage of my build and need to decide on fuel system. The car, Holley dominator EFI controlled gen 3 hemi with 4.5 whipple that will be max at 1000-1100 hp on race gas most likely 20-22 psi max boost. and of course less on premium pump. Only piece of fuel system so far is standard rear mount aluminum fuel cell, no room in front. So would a big brushless rear mount pump be the way to go or 2 smaller staged pumps? Or belt driven front motor plate mounted pump? Or Cable driven? This is a drag week type street/strip 8 second car. Explain benefit of one type over the other and pump recommendations. The car will not ever be ran on alcohol, premium pump and race fuel only. Thanks
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Fuel pump time, recommendations please. [Re: Quickrunner] #2592987
12/16/18 11:19 PM
12/16/18 11:19 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Holley blue
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Fuel pump time, recommendations please. [Re: B3422W5] #2593007
12/17/18 12:19 AM
12/17/18 12:19 AM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted By B3422W5
Holley blue
haha
Re: Fuel pump time, recommendations please. [Re: Quickrunner] #2593019
12/17/18 12:50 AM
12/17/18 12:50 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Aeromotive Eliminator in-tank with Aeromotive PWM Speed controller
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Fuel pump time, recommendations please. [Re: rumblefish72] #2593183
12/17/18 03:26 PM
12/17/18 03:26 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
This is the one!!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Fuel pump time, recommendations please. [Re: Quickrunner] #2593243
12/17/18 04:45 PM
12/17/18 04:45 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would run two pumps, something big and nasty for the track and a smaller unit for the road, both in the tank if you can. Use your EFI to stage the pumps however you need them.
I run two 255LPH pumps and have the second one kick on at 3500rpm if the throttle is over %50. I am NA though and the second pump is mostly for redundancy but I am pretty close to maxing out one pump so I use it under those conditions.
68 Barracuda Formula S 340
Re: Fuel pump time, recommendations please. [Re: Quickrunner] #2593244
12/17/18 04:46 PM
12/17/18 04:46 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have done 6 drag weeks and there is mixed reviews about the pump controllers. I would use a fuel cooler in the return before I ran a controller.
Re: Fuel pump time, recommendations please. [Re: Quickrunner] #2593688
12/18/18 12:03 PM
12/18/18 12:03 PM
CJD AUTOMOTIVE Offline
I'd recommend the Holley brushless pump. It comes with a voltage controller that can be integrated to the Dominator.
The brushless pumps don't have the issue's standard motor pumps have when voltage is reduced, they are unaffected. The Holley controller is simply a 6/12V voltage switch for the pump. The nice part is that at the lower voltage, your not pumping (heating) excess fuel to return to the tank.
You can set up a strategy in the Dominator to switch pump voltage based on whatever parameters you want, or any combination, i.e. boost, TPS %, etc...
I would think the VR1 should handle your power on gas. The VR2 is basically two VR1's joined together.
You can in tank mount the pump, I have a VR2 in my cell.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
