EFI- old MoPar- where to get "true power"? Start/run #2592560
12/15/18 10:50 PM
12/15/18 10:50 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
We are converting a 1969 B body to EFI. Instructions say ECU needs a wire to go to start AND crank 12volt power. Power cannot drop below 9 volts. We tried the ballast, it's a 4 pin ballast, but nowhere do we get sustained 9+ volts during start AND run.
I thought relay maybe? Would 6 volt at ballast pull in a relay?
What has been done for a 1969 B body to get voltage for start and run power at the ECU that works??
CrAzYMoPaRGuY
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592563
12/15/18 10:55 PM
12/15/18 10:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There is no ONE source for that. In start the ignition switch feeds the coil 12v bypassing the ballast, in run the ignition switch shuts that feed off and feeds the coil through the ballast. You need to tie both of those feeds together to get the 12v power your EFI is looking for. Are you using the EFI for ignition as well? If so you can just tie those two feeds together. If you plan to use a separate ignition you will need to use a diode to isolate the feeds from each other while they still feed the EFI.
I'd use those feeds to run a relay and use the relay to feed the EFI direct from the battery.
Don't be the exception.
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592578
12/15/18 11:47 PM
12/15/18 11:47 PM
AndyF Online content
AndyF  Online Content
On my '65 B body I tie start and run together and use the combined switched 12 volt to power the EFI and the ignition system. I also use it to power up the alternator although the alternator really only needs the run line. However, once you tie them together they are together unless you get fancy. My car has been "modernized" so I ditched all of the old Mopar wiring. No more ballast resistor, no more start and run circuits, no more passing all current thru the firewall to the ammeter, etc. Trashed all of that old school Mopar engineering.....
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592581
12/15/18 11:52 PM
12/15/18 11:52 PM
IL
furious70 Offline
furious70  Offline
IL
I did similar to Andy. If you're using modern ignition you don't want the ballast in there anymore reducing the voltage anyway. Tie it together and bypass the ampmeter circuit while you're in there
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592583
12/15/18 11:58 PM
12/15/18 11:58 PM
You can make a doube ended male jumper wire that slides into both of the existing female wire ends at the ballast resistor to do what you need up scope
I do it all the time on street and race cars that I install MSD race boxes or any other ECU that doesn't want the stock Mopar ballast resitor work wrench
Simple and effective scope thumbs grin
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592609
12/16/18 12:48 AM
12/16/18 12:48 AM
Canada
Canada
K so...... we tried many things. The instructions are from the Professional Products kit. It says to go to the power side of the (4 pin) ballast resistor. It also says voltage should not drop below 9 volts at any time.
Voltage drops below 9 volts if wired as it says.
We tried to run side of ballast and it doesn't start as easily as if we run the wire directly to the battery.
We read the instructions again and it says to pull the power directly off the + side of the coil. But not if a ballast resistor is used. This actually works the best by far.
We then thought maybe a relay pulled in by the coil voltage with 12 volts coming directly from the battery might even work better. We are just concerned about pulling a coil in from the positive + coil terminal.
Ma Mopar... what were you thinking? lol
So.... he has an Ehrenberg box I believe the HiRev kit. Can we get rid of the 4 pin ballast somehow?
Argh.
Kit runs pretty danged good, hasn't had time to learn much but it's got throttle response and once running it's no complaint here. We don't want to fry coils and relays and wires by doing things wrong.
"True Power"? Engine maybe! We have ignition 1 and Ignition 2!
We are trying to wrap our heads around the response so far! Thanks. Thanks for being patient!
CrAzYMoPaRGuY
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592614
12/16/18 12:55 AM
12/16/18 12:55 AM
Andrewh Offline
Andrewh  Offline
you might have wired it to the wrong side of the ballast.
check the other pin, see if it stays above 12 volts.
I noticed more than once that the wiring is reversed on the ballast, in that the side you think is going to the coil is not the one it looks like it should be.
since the ballast doesn't care which way the power goes through it, my bet is you are looking at the side coming out instead of going in if you are seeing a drop to 8 volts.
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592617
12/16/18 01:00 AM
12/16/18 01:00 AM
Canada
Canada
Here's our diagrams we used
CrAzYMoPaRGuY
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592618
12/16/18 01:01 AM
12/16/18 01:01 AM
Canada
Canada
We have the 4 pin ballast. We considered swapping to a 2 pin ballast. Whatever works! lol
CrAzYMoPaRGuY
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592645
12/16/18 03:29 AM
12/16/18 03:29 AM
The problem is that you are trying to keep the ballast resistor and stock ignition while also not keeping it. It is easier and cleaner to make up your mind and go one direction.
If you insist on keeping both start and run circuits for your old school ignition setup then you'll have to do something fancy to power your EFI.
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592662
12/16/18 04:39 AM
12/16/18 04:39 AM
Put two jumpers in instead of one up
As Andy has pointed out you may be reading the wrong end of the resistors, bypass both of them up twocents
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592676
12/16/18 10:21 AM
12/16/18 10:21 AM
BDW Online content
BDW  Online Content
I went through this when I did my FiTech.
Simple solution to keep ballast is just add a diode across it.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2387708
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2592683
12/16/18 11:01 AM
12/16/18 11:01 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
We have the ballast still in place and feed the fitech with it's wires. The switched/run 12v source just tells it when you want it to actually run. The b+ 12v source powers the unit as a whole.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: BDW] #2592890
12/16/18 06:50 PM
12/16/18 06:50 PM
Canada
Canada
AWESOME.
Diode hunting we go. Thanks everybody!!!! beer
CrAzYMoPaRGuY
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2593099
12/17/18 12:11 PM
12/17/18 12:11 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
As mentioned, either tie run and start together and use an ignition that does not use a ballast resistor, or put a Diode across the ballast resistor.
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2593203
12/17/18 03:45 PM
12/17/18 03:45 PM
You need to know that all diodes are a one way electrical devise use to stop the current from reversing, flowing backwards, one way work
I'm not sure if they are current limited or not confused Meaning maybe you can you blow them open with to much current shruggy scope They are used to rectify A.C. from alternating to direct current in alternators when used as a full wave circuit shruggy
IHThs
OP, does your EFI and ignition require a specific lower voltage to the ignition ECU? If not bypass the resitors up twocents
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2593621
12/18/18 06:15 AM
12/18/18 06:15 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Yes, Diodes need to be sized for the current flowing through them.
I think the post linked ti mentions a 1N400x diode, but I think those are only rated for 1-Amp, and have a 0.7 volt drop across the diode.
I recall another thread where a 15 amp schottky diode was used.
I think looking up solar array blocking diodes. They also have less voltage drop, about 0.5 to 0.6 volts.
The diodes are pretty inexpensive too.
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2593640
12/18/18 09:17 AM
12/18/18 09:17 AM
BDW Online content
BDW  Online Content
Correct, in the link above there's an EBay link for diodes used in solar panels.
Plenty of current capability and only $1 each.
Here it is again, I put 2 in parallel as a safeguard in case 1 of them fails.
Plus it doubles the current available.
https://www.ebay.com/itm/Pack-Of-10-Scho...a-/381734805254
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: CrAzYMoPaRGuY] #2593698
12/18/18 12:22 PM
12/18/18 12:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Or you could just use that signal to trigger a 30A relay fed directly from the battery and avoid all the old wiring issues.
Re: EFI- old MoPar- where to get "true power"? Start/run [Re: Supercuda] #2593768
12/18/18 02:50 PM
12/18/18 02:50 PM
BDW Online content
BDW  Online Content
Still need to combine start and run, relays aren't small.
