Re: Advice needed for filling O-Ring in block
[Re: vinnyd76]
#2592650
12/16/18 03:41 AM
12/16/18 03:41 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Looking for some Moparts advice for filling a ring groove in a block. A previous owner of a block used an Isky tool o-ringed the block. Now the holes need to be filled with the copper wire (0.040/21-gauge). How do you ensure there is no leak path when the two halves come together? There will be a small gap I’m sure. Anyone have experience with this process and have any advice? Would prefer not to deck the block to remove ring groove. When you install copper or other alloy O rings make sure to file the butting ends square, it takes a little time to get them right, make sure you place the butt end near/at the closest head bolt hole to the ring's outer diameter... Personally I'd go with Stainless O rings and a copper head gasket in your case, SCE O Rings makes a nice Stainless O ring kit Mike
[Re: vinnyd76]
#2594555
12/20/18 02:23 AM
12/20/18 02:23 AM
Posts: 4,457 Washington
madscientist
Washington
Unless you are going to use a dead soft coordinator gasket d use any wire in the groove.
Yo have two choices.
1. Machine the decks own enough to eliminate the grooves. If you have the room to machine that much off that is the best choice.
2. If 1 isn't viable, you need to clean the grooves out until they are as spotless as you can get them. Take some J-B Weld and fill the grooves. Le it dry and the file it down flat and go. I've done it both ways and both work.
[Re: vinnyd76]
#2594705
12/20/18 03:48 PM
12/20/18 03:48 PM
Posts: 43,124 Bend,OR USA
Cab_Burge
What head gaskets are you going to use on the motor? How close are the inner sealing surfaces to the existing grooves in the block?
[Re: Cab_Burge]
#2594709
12/20/18 03:54 PM
12/20/18 03:54 PM
dogdays
[Re: vinnyd76]
#2595839
12/23/18 04:41 PM
12/23/18 04:41 PM
madscientist
Washington
I just used plain old JB weld, but any one of the many now available will work. You just want something solid to fill the groove.
