Page 3 of 10 1 2 3 4 5 9 10
Re: Tired of gratuitous mockup pics yet? [Re: BSB67] #2591362
12/13/18 04:21 PM
12/13/18 04:21 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Originally Posted By BSB67
Originally Posted By davenc
Originally Posted By ZIPPY
collecting info.
Biggest detail is 1 and 3/16 stick out.
I'd like to create a little bit more space between the oil and the rods sticking out. With this pan and a 6qt fill, the oil seems a little too close to the rods for a windage tray/screen to even have much effect.
Zippy,
I had commented on someone else's build that from their pics the windage tray itself was going to be sitting at the oil level....then some other poster pointed out that the oil will not be at that level while the motor is running. I understand deep pans help, but it is worth considering that you may have more separation than you are thinking.
FWIW, I like to consider that too (i.e. the level will be lower when the motor is running), and that it is not sitting level either. I figure that if the oil is at the crank at the back of the motor when stationary and not running, and if the tray is up close to the crank, it'll all be good. No proof though.
I will say that with full time unrestricted oiling to the valve gear, loose bearing clearances and 0W-30W oil, I've never had a problem with oil pressure up to 6800 rpm.
Yes to all, agree with the thought process and was headed down that road. It's pretty well known folks have overfilled for many years with no adverse effects. I do like to know where I'm starting from.
Since I probably won't engine dyno it, the logical thing to do is put a sight tube on it and put a camera under the car on chassis dyno to really know where the oil level is.
I admit the hardest thing for me to consider is the vehicle moving/dynamic environment. It's easier to imagine it sitting static.
Will play around with a few ideas and figure something out, I have an idea which combination(s) to look at next.
Thanks for the encouraging comments!
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2591474
12/13/18 08:22 PM
12/13/18 08:22 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Originally Posted By cdwmotorsports
Originally Posted By AndyF
I don't know if such an animal exists or not but you can get sheet metal valve covers and then weld #12 AN bungs on them for screw in breathers or use AN lines over to the core support for a Moroso 3 qt remote breather tank.
AndyF,
Thank you for this info, I bought the 440source welded aluminum valve covers and was wondering how exactly to handle this problem. I appreciate your knowledge and willingness to help people, i wish everyone on this board would follow your example. Sorry to the OP for the hijack
Hey no need to apologize, pick up any ideas you possibly can from any source, it's all good.
I ran AN lines to a breather tank on my Wedge engine back in 2001
Over a period of time, though, I got tired of the clutter underhood and found it was not needed on that engine, tested up to 7000. Instead I went to OEM replacement 1970 era grommets and matching OE style breathers. Those paired up with baffles inside the valve covers is all it seems to need. But...that was a 3.75 stroke engine.....
Thanks for this info zippy, I have a 451 which IIRC was what you had too. The valve covers I’m using don’t have baffles in them and if I have to weld on them I may as well weld in the bungs now. At some point the 451 will become a spare and the valve covers will move to the new engine.
eBay-cdwmotorsports
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2591502
12/13/18 09:09 PM
12/13/18 09:09 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Anytime. I actually still really like my 451 and want to keep running it for awhile. In this day of aftermarket parts I think it ran pretty well considering it was built on a broke musician's budget (et and mph in signature, alot more left).
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2591650
12/14/18 03:15 AM
12/14/18 03:15 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Therin lies my conundrum, I've heard about some 4.5 stroke combos with street pans having high rpm oil pressure issues. Windage/air?
That was the case with my 572 wedge that Dwayne built a few years back. Tried the street hemi pan/windage tray/internal pickup. On the dyno it was losing oil pressure as the rpms climbed. Dwayne wasn't happy and we went with a Charlies pan with dual pickups....one line to the pump and the other to the port on the front of the block. Dwayne surmised that the long arm was creating (excessive) windage which was wreaking havoc with the oil control. Going off memory the problem began to appear just past 5000rpm on the dyno and oil pressure continued to drop all the way to the 6200rpm redline. work
Worked like a charm with the new oiling system....rock solid oil pressure on the dyno and in the car running down the track. up No windage tray....just a screen that is built-in to the Charlie's pan.
Cool project Zippy !! punkrocka
Ron
[img]http://www.dodgecharger.com/forum/index.php?action=dlattach;topic=64059.0;attach=117478;image[/img]
[img]http://www.dodgecharger.com/forum/index.php?action=dlattach;topic=64059.0;attach=117649;image[/img]
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2591688
12/14/18 09:28 AM
12/14/18 09:28 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Ron I remember that, and our short conversation on the phone back then about the mp block deal.
I've been asking around and have excellent input from both deep pan and shallow pan users, all long time moparts members.
Rich H.
Esse Quam Videri
Re: Starting mockups for a 572 build... ugly pictures [Re: ZIPPY] #2591799
12/14/18 01:36 PM
12/14/18 01:36 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
No issues with mine up to 7900 on the dyno. I didn't want the big & low typical Mopar sump oil pan on the street & wheel stands crushing it. I went with the flat bottom dragster pan & dual external lines & I run a tubular K frame to clear it.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Starting mockups for a 572 build... ugly pictures [Re: ZIPPY] #2591857
12/14/18 02:38 PM
12/14/18 02:38 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I've watched all your posts 6pk, thanks for the input.
It will have a stock or near stock/reinforced K frame for the time being.
If somebody gave me another K frame to modify I would be OK with the old familiar cutting and boxing for a little more clearance, but I am not going to deliberately chase that.
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2591891
12/14/18 03:43 PM
12/14/18 03:43 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
collecting info.
confirmed, the extra deep tray is no good with that pan.
I think what I'd like more is a 1"+ deeper repro pan, like 6".
I always believed that is what some of the f.a.s.t. cars appear to have...or used to...years ago I noticed some of them hang down below the K member but only slightly...
Zippy It's been a while, but if I remember right, there is a stock hemi pan that holds 6 quarts. You can overfill it by a quart or 2, because the hemi holds a lot of oil upstairs when it is running. I modifyed a stock pan by extending the front of the sump forward about an inch, and lowered the bottom of it about 1.5". I was trying to keep stock proportions and a stock look. It added about a quart, maybe 2, to the capacity. I like to use a crank scraper from Ishihara-Johnson. Another thing you can do is mount tubes in the crankcase, where the top of the tube covers the drainback hole from the head, and the bottom of the tube hangs into the pan. This keeps the drainback oil from the heads off the crankshaft.
https://imgur.com/a/m1Ppjkd
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Tired of gratuitous mockup pics yet? [Re: Hemi_Joel] #2591915
12/14/18 04:20 PM
12/14/18 04:20 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
collecting info.
Thanks for repeating the info here Joel, it helps the whole community.
Also thanks again for confirming f.a.s.t. setup, the pans on similar vehicles always looked just slightly bigger as they usually hang down below the K member just slightly.
Will be ordering a couple pieces to play with which should help me decide.
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: Hemi_Joel] #2591926
12/14/18 04:47 PM
12/14/18 04:47 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
do you modify the stock oil pickup when doing this?
Re: Starting mockups for a 572 build... ugly pictures [Re: 6PKRTSE] #2591970
12/14/18 06:10 PM
12/14/18 06:10 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Even with a modified sump you can squish them
Re: Tired of gratuitous mockup pics yet? [Re: krautrock] #2591976
12/14/18 06:36 PM
12/14/18 06:36 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I used a milodon pickup for an 8 quart pan, but I cut itt shorter and re-threaded it.
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2592020
12/14/18 08:06 PM
12/14/18 08:06 PM
Ontario,Canada
Ontario,Canada
Hey Rich,
I tried to attach a few pics but the link didn't work. Send me your e-mail if you want me to send a few pics.
The Charlies pan is a 10qt and I run 9 qts as per Dwayne's recommendations. The fabbed aluminum pan is not a deep sump....hangs a few inches below the K-frame. I have a 2in skid plate that I've been meaning to weld on.....will get to it this season. The pan is long and the center link passes through the pan so it takes a bit more effort to remove the engine. I had to do some minor clearancing on the steering box mount to clear the -12 90* fitting on the back of the oilpump cover. Other than that it went in pretty easy.
That Charlies pan is very nice with lots of baffles/trap doors and built in screen. I wouldn't hesitate to go this route again if I was building a 4.5in stroke deal. up
Ron
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2592293
12/15/18 01:14 PM
12/15/18 01:14 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
thanks Ron, I'd love to check it out, all info is appreciated and could come in handy later.
rhwang3 @ yahoo dot com
To start with I'm going to try a traditional deep sump without the centerlink hole, (have an idea for changes to the shape of the pan) and will see how that works. I have an idea for windage tray/screen that I want to try out also.
I've had a Moroso deep pan on the car since 2001 and never smashed it, however that may be only because I haven't tried hard enough laugh
Great input from all, many of them only in PM....many thanks.
Rich H.
Esse Quam Videri
Re: Starting mockups for a 572 build... ugly pictures [Re: ZIPPY] #2592659
12/16/18 04:20 AM
12/16/18 04:20 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Ok, here is my junk, no hoses for the suction line, its a -12 solid line
the first pics were the interference with a Hemi mount and oil pump suction lines...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Starting mockups for a 572 build... ugly pictures [Re: ZIPPY] #2592660
12/16/18 04:25 AM
12/16/18 04:25 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Ok, this is what I had to make work:
Milodon road race pan, -12 rigid line and Al Debevic had to make a custom motor mount to clear the fuel pump on the other side.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Starting mockups for a 572 build... ugly pictures [Re: ZIPPY] #2592663
12/16/18 04:43 AM
12/16/18 04:43 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Here is what I started out with rockers, factory wide pads, Dvorak Stands and standard height valve, comp 959 spring, Titanium retainers, .080 tall lash caps.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Starting mockups for a 572 build... ugly pictures [Re: ZIPPY] #2592665
12/16/18 04:44 AM
12/16/18 04:44 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Here are some more but I cant seem to attach them
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Starting mockups for a 572 build... ugly pictures [Re: astjp2] #2592684
12/16/18 11:02 AM
12/16/18 11:02 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Aha...thank you.
The shot with the radiator hose is the one I wanted to see. It's tight but looks like it works. I am going to try internal for openers but if it doesn't work out, using that hole in the front of the block is the fall back plan.
Sure, internal pickup or the hole in the front of the block is slightly more restrictive than an external line right to the pump cover but it seems windage is the bigger problem rather than oil delivery. I'm hoping one of these will be the right comprimise for a street/strip app.
Valvetrain looks like a future source of entertainment!
Rich H.
Esse Quam Videri
Re: Starting mockups for a 572 build... ugly pictures [Re: ZIPPY] #2592688
12/16/18 11:15 AM
12/16/18 11:15 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Fill the pan and mark the stick for the amount in the pan itself. You may start with 9 quarts in the motor and only see 7-7 1/2 in the pan after you run it once when new. This way you always know the true pan level. Then you can experiment. With my Charlies pan the stock dipstick hits the bottom of the pan where there is no oil, sump is further rearward and deep. Dragster pans can actually allow a lot of oil to climb up the back of the block on accell unless there is a significant amount of baffling.
Doug
