FUEL LINES ON 71 CUDAS: 383, 440, HEMI AND 340 #2591484
12/13/18 08:41 PM
12/13/18 08:41 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hello!
I was wondering how should the fuel lines be on a 71 cuda
w/ a 340 engine
w/ a 383 4 BBL engine
w/ a 440 4 bbl engine
w/ a HEMI engine-
I know on my 440.6 car I have the 3/8" fuel line, then I have a return line, and I also have a vapor line that goes from the vapor separator to the ECS out back.
How about the other engine configurations listed above?
Re: FUEL LINES ON 71 CUDAS: 383, 440, HEMI AND 340 [Re: domingo] #2591497
12/13/18 09:02 PM
12/13/18 09:02 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
All engines, fuel pump to carbs were 5/16"
Re: FUEL LINES ON 71 CUDAS: 383, 440, HEMI AND 340 [Re: domingo] #2591508
12/13/18 09:27 PM
12/13/18 09:27 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
OK, thanks for that extra info....
but how about the rest of the stuff I had listed for the 440.6....how does that work out for the other engines?=
Re: FUEL LINES ON 71 CUDAS: 383, 440, HEMI AND 340 [Re: domingo] #2591574
12/13/18 11:51 PM
12/13/18 11:51 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
1/4" return line
5/16" vapor line -
regardless of engine size ( if equipped as such obviously )
Re: FUEL LINES ON 71 CUDAS: 383, 440, HEMI AND 340 [Re: domingo] #2591892
12/14/18 03:44 PM
12/14/18 03:44 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Right,,,,but did all engines in 71 came with return and vapor lines?
Re: FUEL LINES ON 71 CUDAS: 383, 440, HEMI AND 340 [Re: domingo] #2592298
12/15/18 01:26 PM
12/15/18 01:26 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
?? bump ??
Re: FUEL LINES ON 71 CUDAS: 383, 440, HEMI AND 340 [Re: domingo] #2592304
12/15/18 01:39 PM
12/15/18 01:39 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Only 440 and Hemi had the 1/4" return line.
440 and Hemi had 3/8" supply line.
340 and 383 had 5/16" supply line.
All 71's had the 5/16" vapor line
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: FUEL LINES ON 71 CUDAS: 383, 440, HEMI AND 340 [Re: domingo] #2593385
12/17/18 09:47 PM
12/17/18 09:47 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
thanks!!!
