New to the Gen3 #2591160
12/13/18 01:53 AM
12/13/18 01:53 AM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
I'm just getting into this new Hemi stuff, I'm wanting to build one for my street rod. I have a core 5.7 I can get for $500, problem is, it appears to be locked up and a nasty oil film in the intake.
Initially I wasn't too concerned since was a core engine, but, the more I learn that these are bad about seats dropping.
Question is, should I just walk away from this one?
Re: New to the Gen3 [Re: PS Arrow] #2591187
12/13/18 04:41 AM
12/13/18 04:41 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Tear it apart and see what's going on... I've never personally saw one drop a valve, mostly spun rod bearings.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: New to the Gen3 [Re: PS Arrow] #2591206
12/13/18 09:49 AM
12/13/18 09:49 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
late 04-06 there was a seat issue, it was a supplier small player it's one of those 1 out of 10k deals but it gets talked up more and more every year. over on the LX forum it's like a death nail item to some low info buyers.
I wouldn't walk away, but I would push the issue of wanting to see it with the top end removed, if the Valve broke it can tear up a Cylinder wall pretty good....don't fear having a sleeve put in one of these.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: New to the Gen3 [Re: PS Arrow] #2591295
12/13/18 01:45 PM
12/13/18 01:45 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I bought 2 locked up 5.7s and both dropped seats on the same cylinder. Blocks were fine but the heads were junk.
I wouldn't buy it for %500 if you have to sleeve it.
Re: New to the Gen3 [Re: PS Arrow] #2591338
12/13/18 03:18 PM
12/13/18 03:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Not worth $500, I have bought ones with broken rods and no holes in the block for that much. I have seen one with dropped seats (owner severely overheated it) and one with a spun rod bearing(looked like they never changed the oil, severly sludged), I have seen tons o broken rods in the 03-08 5.7s, I would rather buy one of those and stick another rod in it, just be sure there is no hole in the block, they are almost always visable from the outside and only about 1/2 poke through the block, most of them still rotate.
Re: New to the Gen3 [Re: Silver70] #2591704
12/14/18 10:50 AM
12/14/18 10:50 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Got to go with this one.
Grab some tools and have at it. You may just be able to have a decent block for free.
Spun rod or messed up head does not equal 500.00
Re: New to the Gen3 [Re: PS Arrow] #2591711
12/14/18 11:01 AM
12/14/18 11:01 AM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
The big question is what year is the engine? 09 or newer, the heads a lone are worth 500
