Battery ID from broadcast sheet #2590682
12/12/18 01:47 AM
12/12/18 01:47 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Where in factory literature can the info from a build sheet identify the proper battery a car was built with? Line 3 of the build sheet in the bat box is the number 62. I assume this is the last 2 digits of the battery part number but where in the parts manual can a battery part number be found? Also line 7 block F of the build sheet is F23 in the battery box, where in factory literature can F23 be decoded? I do believe this is a 59amp hr group 24 yellow cap but would like to know for sure from factory documentation. Can anyone help? Thanks
Re: Battery ID from broadcast sheet [Re: 340cpe] #2590805
12/12/18 12:47 PM
12/12/18 12:47 PM
New York
rarefish Offline
rarefish  Offline
New York
What year broadcast sheet are wee talking about?
62 in the battery box on line 3 would be a 59 amp yellow cap batter for a 1971 383 engine and a 1971-73 340 engine.
Re: Battery ID from broadcast sheet [Re: 340cpe] #2590979
12/12/18 06:48 PM
12/12/18 06:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Which plant also? Windsor typed stuff into the F section at times that is not battery related.
Re: Battery ID from broadcast sheet [Re: 340cpe] #2591111
12/12/18 11:41 PM
12/12/18 11:41 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
I’m sorry it is a 71 bee and is a 383 built in Lynch Road. Thanks rarefish, So the question is where would one find the information that you gave me in any Chrysler documents/literature like parts manuals service manuals etc.? Is the 62 the last two digits in the part number and if so where would one look that info up? I cannot find batteries listed in a factory parts manual. I did find in a aftermarket code book that F23 is a 59amp/hr yellow cap but it is just driving me crazy that I can’t find this info in a factory literature that I have. Alaskan_ta Thanks also for letting me know that build sheets could give different info depending on assembly plant.
Re: Battery ID from broadcast sheet [Re: 340cpe] #2591523
12/13/18 10:09 PM
12/13/18 10:09 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
My 71 Cuda 383 convertible has "62" in the battery slot on the build sheet as well. I have interpreted this mean it should be battery 2444562. My main reasoning is that I know it should have a group 24 battery and this is a group 24 battery with the last two digits matching up to the build sheet.
Mike Afflerbach
Re: Battery ID from broadcast sheet [Re: 340cpe] #2591612
12/14/18 01:38 AM
12/14/18 01:38 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Cudaize where did you find that pat number?
Re: Battery ID from broadcast sheet [Re: 340cpe] #2592087
12/14/18 10:18 PM
12/14/18 10:18 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
It's listed on page 13 of the AMA specifications for 1971 Barracudas for 383's only 2444562, 12 Volt 56 Plates, 59 Amp-Hour.
slant six, 318, 340 is listed as 2875951, 12 Volt, 54 plate, 46 Amp-Hour
426 Hemi and 440 ^barrel are listed as 2642969 12 volt, 78 plate, 70 Amp hour
Re: Battery ID from broadcast sheet [Re: 340cpe] #2592170
12/15/18 02:01 AM
12/15/18 02:01 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Please forgive me I’m not good at all with acronyms, what is AMA?
Re: Battery ID from broadcast sheet [Re: 340cpe] #2592177
12/15/18 02:22 AM
12/15/18 02:22 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
AMA - American Manufacturers Association
Example pages at http://www.hamtramck-historical.com/ama/1970AutomobileManufacturersAssociation-01.shtml for 1970 Plymouth & Barracuda, but we do not have a 1971 set available for the HH Library yet.
