LED Voltage "Gauge" You May Need? #2590121
12/10/18 11:19 PM
12/10/18 11:19 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Since it’s not uncommon to delete the ammeter and have to add a volt gauge somewhere, here’s a solution you may not be aware of.
This LED needs a 14mm hole, power, ground and it will tell you everything a volt gauge will.
On my dash, i determined a voltmeter wasn’t mission critical enough to dedicate a gauge slot to, so I recently went to this LED version.
As you can see in the image, it provides color and flashing feedback depending on voltage conditions, which is pretty neat.
eBay link as of 12/10/18
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F190401283689
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: LED Voltage "Gauge" You May Need? [Re: GoodysGotaCuda] #2590133
12/10/18 11:41 PM
12/10/18 11:41 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
wow! thats nice! easy to add on regular ammeter.
Lebarons/Diplomats already got an integrated light indicator on ammeter to tell about voltage, with an integrated circuit board attached to the back of gauge, but this tells way more smile
Re: LED Voltage "Gauge" You May Need? [Re: GoodysGotaCuda] #2590144
12/10/18 11:56 PM
12/10/18 11:56 PM
BDW Offline
BDW  Offline
Very slick, I've been using digital that pushes into the cigarette lighter, but this is nice.
Re: LED Voltage "Gauge" You May Need? [Re: BDW] #2590155
12/11/18 12:23 AM
12/11/18 12:23 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have one of those but the ashtray door gets in the way in 5th gear. This, so far, seems like a good solution to keep it relatively in my line of sight.
2020 RAM 1500
Re: LED Voltage "Gauge" You May Need? [Re: GoodysGotaCuda] #2591886
12/14/18 03:34 PM
12/14/18 03:34 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
I installed a 2 port usb charger in my console and it also functions as a voltmeter.
Like $16 off amazon. Works great, I also have the plug into cig lighter version on my truck.
Re: LED Voltage "Gauge" You May Need? [Re: MileHighDart] #2592045
12/14/18 08:39 PM
12/14/18 08:39 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Got a link? I add interesting stuff like this to my wish list.
Re: LED Voltage "Gauge" You May Need? [Re: MI_Custumz] #2592061
12/14/18 09:03 PM
12/14/18 09:03 PM
Lyons, CO
Lyons, CO
Just go to Amazon dot com
And search for 12v usb Charger.
There are several different ones to chose from.
Re: LED Voltage "Gauge" You May Need? [Re: MileHighDart] #2592240
12/15/18 10:51 AM
12/15/18 10:51 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I like those and do own one just like that. With the cig lighter in the ashtray on my car, the shifter hits the door in 5th and reverse.
2020 RAM 1500
