Throttle control Question #259003
03/19/09 11:14 AM
03/19/09 11:14 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
I'm wanting to install this Dedenbear throttle control with this bracket and find the electric switch is going to hit the cable bracket when it is positioned the way is was intended to be installed. {switch down}
can the electric switch be removed and remotely mounted having the hose attached directly to the throttle control from the remotely mounted switch?
Thanks.
Re: Throttle control Question [Re: Rodney] #259004
03/19/09 07:57 PM
03/19/09 07:57 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
you should be able to loosen the jam nuts on eather side of the "stop"and rotate the selenoid
were ever you want!
Re: Throttle control Question [Re: boatracer572] #259005
03/20/09 08:45 AM
03/20/09 08:45 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
ok I will try that, it seems to be my only option at this point.
I was thinking it wouldn't be a good idea but after looking at it some more it should work ok.
I talked with tech {not dedenbear} & they suggested I do not mount the solenoid remotely.
FYI Dedenbear has been bought out by Autometer Co. and first impression no real tech support at this time for Dedenbear.
Re: Throttle control Question [Re: Rodney] #259006
03/20/09 11:05 AM
03/20/09 11:05 AM
San Jose Ca.
San Jose Ca.
I agree with you on the tech support,But for such a big company they are very willing to help the little guy!I had a NOC-1 fixed at there place,they shiped It back with the wrong board installed,I was leaveing for a race In two days,Florance sent me a brand new Noc-1 overnight at no charge to me so I could make my race!not often a big company will do that for the little guy! Im a Dedenbear user for life!!!!
Re: Throttle control Question [Re: boatracer572] #259007
03/20/09 11:51 AM
03/20/09 11:51 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
Your right, I gave them another call and Doug got right back to me and is sending me a bolt I needed, no charge! I simply didn't talk with the right person the first of the week.
