Would you run a solid roller with ductile rockers? #2589958
12/10/18 06:29 PM
12/10/18 06:29 PM
junction city oregon
V
viperblue72 Offline OP
V
I am currently building a 408 w2 engine that’s gonna be a pump gas mostly street some strip. I already have bushed ductile rockers and want to run a solid roller.
If it’s not recommended to run a roller with them I plan to run a solid flat tappet since another 1000+ for rocker arms won’t justify the cost. I plan to run something around
250-255@050 and .600 valve lift.
What are your opinions?
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2589967
12/10/18 06:42 PM
12/10/18 06:42 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I ran a set of unbushed rockers on my 440 years ago with a 695 mushroom tapping cam for years. Strip only car but we raced 2-3 times a week.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2589971
12/10/18 06:53 PM
12/10/18 06:53 PM
gregsdart Offline
gregsdart  Offline
Seems to me it will be about the intensity of the lobes, and how much they stress the rockers, not what type of lifter they use. A street roller would probably be easier on the rockers than a race flat tappet. My geuss is an endurance roller lobe would be worth looking at, and find some of the OLD big name engine builders from the 60s or early 70s, as they probably tried everything. I know for instance that Crane Gold rockers will stand up to a .750 lift superstock roller, at least for a while. I broke the crank before i put many runs on that setup.
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2589973
12/10/18 06:58 PM
12/10/18 06:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your on the margin.. do you know the max lift
of the cam
wave
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2589975
12/10/18 07:07 PM
12/10/18 07:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
“I wouldn’t”, but I’m sure many have.
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2589976
12/10/18 07:09 PM
12/10/18 07:09 PM
V
V
Pbody- I plan to run something that is approximately.400 lobe lift.
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2589981
12/10/18 07:18 PM
12/10/18 07:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At about .400 lift I would.. sweep is minimal
if its set up right.. assuming this is some
street grind cam
wave
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2589984
12/10/18 07:24 PM
12/10/18 07:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I ran a roller with them for many passes on a 440. Never an issue.
Doug
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2589990
12/10/18 07:38 PM
12/10/18 07:38 PM
Washington
madscientist Offline
Washington
That rocker is better than most of the junk that was sold out there.
If it's bushed, make sure it has full oil and keep idle oil pressure and flow up. I've run .750 net rollers and 340 on the seat with those rockers.
If you break that rocker, it's a geometry issue, or some other problem like a binding issue.
I'd pay to run those before I'd use a set of HS rockers for free.
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2590054
12/10/18 09:16 PM
12/10/18 09:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Careful inspection for minor surface imperfections. If any catch your fingernail (high precision instrument) just blend them into the casting with a fine stone until you can't feel it. Especially careful of lower surface of valve-side lever.
Any sign of relieving, machining for spring or retainer OD?
If you're really nervous, cryo treatment may make you feel better.
Yes, I'd run them.
Boffin Emeritus
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2590088
12/10/18 09:52 PM
12/10/18 09:52 PM
V
V
Whatever I run will be a street type roller. I wasn’t so much worried about durability of the rocker, but wear and tear on the guides and valve tips etc. The last street roller I ran was 200 seat pressure and 560 open, although it probably never saw 560 with only .580 lift.
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2590100
12/10/18 10:14 PM
12/10/18 10:14 PM
Washington
Washington
If the geometry is correct, the guides won't wear out. That rocker is highly underrated. To you have the econo head or the are you using offset blocks and shafts?
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2590117
12/10/18 11:01 PM
12/10/18 11:01 PM
AndyF Offline
AndyF  Offline
Should work fine for you since I doubt that you put very many miles on the combination.
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2590135
12/10/18 11:46 PM
12/10/18 11:46 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I bought a good used set from Andy for my 451 with .654 mushroom (272@.050) and 140#/430# springs. I expect they will last a good long time too smile
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2590170
12/11/18 01:03 AM
12/11/18 01:03 AM
Many,many , many SS Mopar racers used them for years and years.
I'm sure there a decent piece to start with for the W2 so I wouldn't hesitate at all on using them up
John Dieanna used them on his old M.P and later Comp Eliminator W2 motors, he let the clutch out at 8200 and shifted it around 8800 RPM work As far as I know he never broke one either up
Re: Would you run a solid roller with ductile rockers? [Re: madscientist] #2590204
12/11/18 02:09 AM
12/11/18 02:09 AM
V
V
These are the w2 race head.
Re: Would you run a solid roller with ductile rockers? [Re: viperblue72] #2590247
12/11/18 05:11 AM
12/11/18 05:11 AM
Washington
Washington
Then you should have offset stands and shafts. Make sure the stem height is correct. Then you adjust the stand height to correct the geometry.
If you get that right, those rockers are good to at least 8800 RPM with the spring loads I posted earlier.
