Holley #2587784
12/05/18 09:59 PM
12/05/18 09:59 PM
florida dade
cesar perez Offline OP
florida dade
Can any one give info on a dominated car list #80823 is it a 2 or 3 circuit is it used for single or tunnel ram iam pretty sure it's an 1150 cfm thanks
Re: Holley [Re: cesar perez] #2587817
12/05/18 11:12 PM
12/05/18 11:12 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If that number is supposed to read 8082-3 then it is a 2 circuit intended for a single carb application, and it is a 1050 cfm internal linkage, the one I have works good.
Re: Holley [Re: cesar perez] #2588134
12/06/18 04:29 PM
12/06/18 04:29 PM
Mark Whitener Offline
8082 is a 2 circuit, but most of the Dominators need calibration help for single or dual carb use. What do you want too use it for?
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Holley [Re: cesar perez] #2588544
12/07/18 12:58 PM
12/07/18 12:58 PM
florida dade
florida dade
Alcohol tunnel ram
Re: Holley [Re: cesar perez] #2588809
12/07/18 10:08 PM
12/07/18 10:08 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Modifying gas carbs to alcohol can get fairly expensive, especially when you have 2 of them. I am going through the same thing. Putting my gas Dommies on the shelf for a while. Keeping an eye out for a set of Quick Fuel 1150 alky dommies. Found one for the right price. Already picked up an Enderle 80A 0.5 fuel pump.
Re: Holley [Re: cesar perez] #2589383
12/09/18 03:04 PM
12/09/18 03:04 PM
It's about $600 each to convert a Dominator to methanol. And methanol is one of the few I would suggest using a 3 circuit carb for.
Mark Whitener
Re: Holley [Re: cesar perez] #2589801
12/10/18 01:39 PM
12/10/18 01:39 PM
florida dade
florida dade
These are converted all ready but they are 2 circuit is this a good choice
Re: Holley [Re: cesar perez] #2589802
12/10/18 01:39 PM
12/10/18 01:39 PM
florida dade
florida dade
Re: Holley [Re: cesar perez] #2589866
12/10/18 03:22 PM
12/10/18 03:22 PM
sgcuda Offline
sgcuda  Offline
For the most part, 2 circuit carbs work fine. Some might argue that a 3 circuit would be more beneficial after a certain power level, due to fuel demand. It all depends on what you are running. The QF 1150 alky carbs I'm getting are 2 circuit.
Re: Holley [Re: cesar perez] #2589870
12/10/18 03:27 PM
12/10/18 03:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
Go try what you have now and then decide if they work good enough for your deal work If not then think about what those carbs need to have changed to make you happy up
