RAM TECHS? 08 RAM STALLS AT STOPLIGHT
#2588981
12/08/18 11:04 AM
12/08/18 11:04 AM
crabman173
crabman173
Guys I have an 08 Hemi Ram--Great truck with 200K pampered miles every now and then you are cruising along and when you come to a stop it will stall--fires right back up and no big deal does it once every 6 months but has done it twice in two days now--what is up? What do i need to replace, clean, fix?? Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: RAM TECHS? 08 RAM STALLS AT STOPLIGHT
[Re: ]
#2589062
12/08/18 04:34 PM
12/08/18 04:34 PM
Posts: 16,840 Between Houston & Galveston TX
SattyNoCar
How old is the battery? Is the alternator charging fully? I've seen quite a few late models that 'fired right up' but had idle/stalling issues because the battery was actually weak. The systems in new(er) vehicles are much more dependent on having a specific voltage. My to give this a
John
[Re: ]
#2589068
12/08/18 04:51 PM
12/08/18 04:51 PM
crabman173
crabman173
Has one year old Interstate but i will check it--someone else mentioned throttle body issues as it is fly by wire--I just did not know what the heck it could be Thanks
[Re: ]
#2589249
12/09/18 02:37 AM
12/09/18 02:37 AM
Posts: 954 garnett kansas
rhad
garnett kansas
does drive by wire have a IAC valve?
my ladder of success is missing some rungs
[Re: ]
#2589326
12/09/18 01:37 PM
12/09/18 01:37 PM
crabman173
crabman173
Thanks everyone i will check the EGR was told throttle body because it is drive by wire so any ideas on that? Thanks
[Re: ]
#2589481
12/09/18 05:48 PM
12/09/18 05:48 PM
crabman173
crabman173
Nope never touched it so guessing take it off spray it out?
[Re: ]
#2589486
12/09/18 05:59 PM
12/09/18 05:59 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
Definitely clean the throttle body. You can probably get by with just pushing it open and using a rag with brake or carb cleaner to remove the carbon buildup unless it's really bad.
I also had issues with the crank position sensor on mine. I would occasionally have stalling problems, usually coasting down to a light. It lost crank signal once, then took forever to start a year or two back. Replaced it and it hasn't stalled since. Hard to verify that though without a scantool on it when it's acting up for you.
[Re: ]
#2598069
12/28/18 06:05 PM
12/28/18 06:05 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Guys I have an 08 Hemi Ram--Great truck with 200K pampered miles every now and then you are cruising along and when you come to a stop it will stall--fires right back up and no big deal does it once every 6 months but has done it twice in two days now--what is up? What do i need to replace, clean, fix?? Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! My 2003 will do that same exact thing every few months. Thanks for posting as i will try some of the ideas listed here. Stu
