Page 2 of 4 1 2 3 4
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2588489
12/07/18 10:31 AM
12/07/18 10:31 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
The bolt in sprag, as others have said, is not necessary. The only reason I would use one is if the stock sprag was loose in the case or had obvious problems.
I tyically build 4-5 727's a year for local guys and never have an issue there.
The 727 in my car holds well over 700HP on spray and it is surprisingly stock! LBA Turbo Action fwd pattern valvebody, good clutches and steels and governor removed (not necessary, but just less parts to fail if removed.)
'63 Dodge 330
11.19 @ 121 mph
Re: When is a Race trans not a race trans.... [Re: dOrk !] #2588490
12/07/18 10:32 AM
12/07/18 10:32 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By Doc Fiberglass
I would rather SPEND DA BUCKS on a good drum than CHANCE blowing up a trans ... losing the case .... destroying the valve body and MAYBE hurting the converter !!
Which brand(s) have you used and why?
'63 Dodge 330
11.19 @ 121 mph
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2588517
12/07/18 12:06 PM
12/07/18 12:06 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have been racing mopars since 1974, never had a trans blowup or even burn one up, knock on wood. Always built my own. I have seen several of my buddies blow up over the years, lucky only minor injuries. With the damage possible to car and humans, it is only smart to use a good drum. I like the aluminum drum with the stainless sleeve, good friction surface and lightweight. The problem is most valvebodies do not hold the rear band in low gear, that plus the stress of not doing a burn out right is what causes the issue of sprag failure. I have used the low band apply valvebody, because it is safer, but in my testing the regular manual valvebody, that does not hold the band is a little faster. The low band was just not designed to be released quickly. Which is what you need for a clean 1-2 shift. Even with the modified low servo, just my opinion.
http://www.tcsproducts.com/media/1/TCS_TF727_Performance_Transmission_Parts.pdf
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2588631
12/07/18 03:30 PM
12/07/18 03:30 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Correct me if I’m wrong but isnt the low band applied in all forward gears if you have LBA valve body. The 1-2 shift has the kickdown band apply with no change to the rear band. The 2-3 shift releases the kickdown band and applies the front clutches?
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: When is a Race trans not a race trans.... [Re: FurryStump] #2588644
12/07/18 03:58 PM
12/07/18 03:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No. It releases on the 1-2 upshift.
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2588669
12/07/18 04:57 PM
12/07/18 04:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You can weld a small piece on the strut to reinforce it at no cost. The standard bolt in sprag does nothing. It to repair a damaged case, nothing more.
Doug
Re: When is a Race trans not a race trans.... [Re: John_Kunkel] #2588729
12/07/18 07:26 PM
12/07/18 07:26 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Ok thanks!
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2588763
12/07/18 08:30 PM
12/07/18 08:30 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Originally Posted By Moparmal
Gday Tex.
So what is the story? I have a Griner/Cope RMVB to swap in.
Where I’m stuck is the d3cision on the sprag and 2/3 strut...I think the bolt in sprag is a must...haven’t heard much about struts failing.
If building a big sprag will not hurt , strut bar yes a heavy duty or billet one us good
Low band apply only way to go especially street driven
If you are starting from scratch and are seriouslly racing put a billet drum in . Though my footbrake trans has a stock drum , it was 65/6600 throuh the traps
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: When is a Race trans not a race trans.... [Re: dvw] #2588841
12/07/18 11:09 PM
12/07/18 11:09 PM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
DVW - Thx for clearing that up. Maybe I’m being paranoid, but my buddy cocked a roller in his sprag by simply jumping on-off and then on the throttle again. (Car got loose on him in the street)
Tex - I have a LBA valve body from CRT so an exploding drum is not my concern - a spinning sprag or busted rollers is....simply because of repair costs.
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2588908
12/08/18 01:53 AM
12/08/18 01:53 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Mal,
Sprag failure is a bit luck of the draw in my opinion .
High HP and or high rpm needs a drum .
Make your own call after adking and thinking . Then hang on for the ride
Tex
New best MPH 130.32
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2588917
12/08/18 02:25 AM
12/08/18 02:25 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
As usual Doug’s info is spot on.... personally my $.02 is that if the car is going to see a track, put the good drum in it!
Re: When is a Race trans not a race trans.... [Re: J_BODY] #2588998
12/08/18 12:05 PM
12/08/18 12:05 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Adding a bolt-in over-running clutch adds to the prevention of turning in the case should the situation arise in my opinion. The 4 bolts add to anti-rotation protection over a set screw, aluminum interference and staking. twocents And right or wrong I always use an aluminum front drum in a race build.
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2589004
12/08/18 12:41 PM
12/08/18 12:41 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....actually a bolted in aftermarket “super sprag” can take the case out if it fails. Just some forces involved there that you can’t do a lot about when mayhem sets in.
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2589021
12/08/18 01:39 PM
12/08/18 01:39 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
dont let this happen
Re: When is a Race trans not a race trans.... [Re: dart games] #2589029
12/08/18 02:08 PM
12/08/18 02:08 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
And contrary to popular belief, it doesn't take big horsepower to do that. If the sprag/overrunning clutch fails, a stone stock 318 is capable of causing that kind of carnage.
A drum explosion is strictly a product of RPM x first gear ratio, 2.45.
Kevin
Re: When is a Race trans not a race trans.... [Re: Twostick] #2589037
12/08/18 03:09 PM
12/08/18 03:09 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Kevin
I saw one let go in a 340 Barracuda dialed 13:70, so yes, it can happen to anyone.
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2589270
12/09/18 06:49 AM
12/09/18 06:49 AM
Washington
skrews Offline
skrews  Offline
Washington
^ Yep
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2589285
12/09/18 11:46 AM
12/09/18 11:46 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
.....and least we forget - TEARING UP the floor of the car and even the dashboard !!
NOT TO MENTION possible personal injury to your feet !!! eek
Re: When is a Race trans not a race trans.... [Re: Moparmal] #2589307
12/09/18 01:09 PM
12/09/18 01:09 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Currently putting together a 1966 727. More HD than race, the Super Sprag and Billet drum are out of the budget.
Changes so far have been replacing the 19-spline input shaft with a 24-spline input shaft so torque converter choice is easier. Rear vent, and sprag lube hole from the cooler return. Threaded restrictor plug in case. FT-2 Shift Kit using the stock '66 servos, stock 3.8:1 band lever.
Have an old rebuild kit where all the clutches were supposed to be Alto red eagles, but bulkpart shipped alto read eagle rear clutches and Raybestos Green (High Energy) front clutches. Kolene steels for both clutch packs.
The trans looked pretty good and stock with maybe one rebuild (low mileage car.) No stripped threads in the case, sprag still tight in the case, but previous rebuilder had many of the sprag roller springs installed backwards. Might install a later dual "O"-ring rear band pin.
Haven't decided on bands yet. The stock bands look fine and thinking of reusing them, but I have a new Mopar Performance Front band on the shelf. I think it is Kevlar? Not sure if I should install it or not.
Need to still get a trans cooler and maybe a deep pan.
Re: When is a Race trans not a race trans.... [Re: 451Mopar] #2589343
12/09/18 02:04 PM
12/09/18 02:04 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
This is the exact setup I do for guys that want a good street/strip trans. In addition, we usually add the governor of their choice if they want to leave it in drive and have it shift on its own at a desired rpm. I ALWAYS tell them to shift into 2nd during a burnout and to let me tear it down if they break a driveline component to check the sprag.
I have used both stock bands and rebuilder bands with zero issues.
Page 2 of 4 1 2 3 4
