Lost ignition key - how to remove ignition lock cylinder? #2588599
12/07/18 02:19 PM
12/07/18 02:19 PM
A727Tflite Offline OP
Remove the door lock and have a key made from it or is there an easier method ?
1971 model year mope.
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2588630
12/07/18 03:26 PM
12/07/18 03:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The door lock & ignition cylinders have a key code on them, anyone with the proper key cutter & that code can make a new key.
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2588727
12/07/18 07:17 PM
12/07/18 07:17 PM
Chicago
PurpleBeeper Offline
Chicago
Also, a good locksmith can cut a key without a code. There are only so many "teeth combinations" that are possible & it's not nearly as many as you'd think. I don't fully understand this, but a buddy of mine is a locksmith & only took about 10-15 min. to cut me a new set of keys.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2588736
12/07/18 07:40 PM
12/07/18 07:40 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
For 1969 up there are 3,360 possible combinations for ignition & trunk keys in my book - if I counted right.
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2588902
12/08/18 01:45 AM
12/08/18 01:45 AM
Thanks, didn’t know the locks had codes on them.
I would then assume the trunk lock has a code too.
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2588911
12/08/18 02:04 AM
12/08/18 02:04 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Here is one example from a '70 ignition cylinder I have here;
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2588944
12/08/18 04:06 AM
12/08/18 04:06 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
true, but the trunk key (ES) is different from the ignition/doors (EP)
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2588957
12/08/18 06:45 AM
12/08/18 06:45 AM
Yes, I know the trunk key is different, that’s why I asked if the trunk lock had a code as well.
Now I have to just pull the door panel and get to work. The trunk luckily is open so I don’t have to crawl through the back seat.
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2588999
12/08/18 12:13 PM
12/08/18 12:13 PM
BDW Online content
BDW  Online Content
Would it be possible to key trunk same as the door?
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2589002
12/08/18 12:36 PM
12/08/18 12:36 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Partsmix sells complete kits for that so you can drop down to one key per car
www.partsmix.com
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2589074
12/08/18 05:05 PM
12/08/18 05:05 PM
BDW Online content
BDW  Online Content
Thx, not interested in buying and changing whole set, but this tells me it's possible.
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: Alaskan_TA] #2589119
12/08/18 08:26 PM
12/08/18 08:26 PM
Chicago
Chicago
You know, that's what I always thought, but my buddy told me differently. Maybe I didn't understand exactly what he was telling me, but he didn't seem to have too much trouble.
He had a tool that kinda-sorta looked like a pair of sideways hedge shears...kinda-sorta. He put a blank key in it horizontally & squeezed the handle to cut the teeth. He cut, tried key, cut, tried key and threw away the first key after about 3 cuts and repeated with a new key. By the 3rd blank key he had it. I was amazed. This was on a "brand-X" (Oldsmobile...'78 I believe)
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2589130
12/08/18 08:53 PM
12/08/18 08:53 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Those sheers were a key cutter.
I do not have the Olds book, just the Mopar book.
Re: Lost ignition key - how to remove ignition lock cylinder? [Re: A727Tflite] #2589186
12/08/18 11:18 PM
12/08/18 11:18 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have the same cutter and book. I have a pin set as well to change the cly for a new key. There are five possible pin lengths for each of the five positions on the key. I’ve seen good locksmiths have a soft key that marks easy so they know where to cut for a longer pin. I guess it could be done but the number on the cly and the stuff I have, makes it easier.
