Re: Who manufactures an aftermarket tube chassis for 70 e body?
[Re: Lost in life]
#2589092
12/08/18 06:26 PM
12/08/18 06:26 PM
Posts: 3,461 Dandridge TN
Dabee
Dandridge TN
Give chassis engineering a call. I used this chassis on my 73 Cuda. It also is available in mild steel. If you have good fabrication skills it’s an easy build. https://chassisengineering.com/documents/5010.pdfOpps, My bad your looking for a sgreet chassis not a drag chassis
[Re: Lost in life]
#2589115
12/08/18 08:20 PM
12/08/18 08:20 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Looking at he first picture of the rolling chassis I wouldn't recommend nor use that frame tsk The main reason is the lack of cross frame stiffeners and the lack of a frame beyond the rear end mounts and into the rear of the unibody I believer those chassis are meant to tie into the original unibody. So the unibody takes the place of the cross members you're concerned about.
[Re: Stanton]
#2589137
12/08/18 09:05 PM
12/08/18 09:05 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Looking at he first picture of the rolling chassis I wouldn't recommend nor use that frame tsk The main reason is the lack of cross frame stiffeners and the lack of a frame beyond the rear end mounts and into the rear of the unibody I believer those chassis are meant to tie into the original unibody. So the unibody takes the place of the cross members you're concerned about. It does say to weld part of the frame into the rear passenger compartment, to me that is not enough to help stiffen the chassis Especially if it is a car from east of the Rockies with the normal rust damages done to the bottom of the cars back there from road salts ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Being a SO CA desert guy I have only seen that stuff in pictures on our Mopars ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: Lost in life]
#2589218
12/09/18 12:38 AM
12/09/18 12:38 AM
Posts: 22,731 Bitopia
jcc
Bitopia
That's a triangulated 4 link chassis (?), if you want to slow your Mopar, this is a proven solution.
Don't take my word for it (you likely won't anyway), do your homework.
[Re: Lost in life]
#2589283
12/09/18 11:29 AM
12/09/18 11:29 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
That's a triangulated 4 link chassis (?), if you want to slow your Mopar, this is a proven solution. A long time chassis builder told me this is true for any make of vehicle, not just Mopar. However, if you're not building a car that's going to see more track than street, who cares. The likelihood of ever owning the fastest street car around is pretty slim, so build what you like and can afford and pick your fights carefully !!
[Re: RROD]
#2589317
12/09/18 01:26 PM
12/09/18 01:26 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
Looking at the web site and pics all I can say is he!! no......Ill stick with my "weak" unibody. clean engine bay? their stuff looks way more intrusive than a hemi in an Abody. expensive junk...
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: yella71]
#2589323
12/09/18 01:33 PM
12/09/18 01:33 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Might give Art Morrison a call. They’ve been around for over 30 years. I’m sure they’ve done a Mopar or two.
Abe Lincoln
[Re: Stanton]
#2589351
12/09/18 02:20 PM
12/09/18 02:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
That's a triangulated 4 link chassis (?), if you want to slow your Mopar, this is a proven solution. A long time chassis builder told me this is true for any make of vehicle, not just Mopar. However, if you're not building a car that's going to see more track than street, who cares. The likelihood of ever owning the fastest street car around is pretty slim, so build what you like and can afford and pick your fights carefully !! At $10k for the chassis you better seriously "like" it. PT Barnum comes to mind...
[Re: Lost in life]
#2590993
12/12/18 07:25 PM
12/12/18 07:25 PM
Posts: 3 Woodstock, IL
Schwartz Perf
Woodstock, IL
Hey all,
Sounds like you're all a little skeptical about the full frame deal.. We've built several cars including 800+hp Mopars with our setup, and I can tell you they handle, ride & drive great and yes they improve the strength of the car. Have you counted the spot welds holding the stock front end to the firewall?
Triangulated 4 links are nice since they have plenty of adjustment, and we use high quality teflon-lined rod ends so they're quiet and allows the axle to articulate. Haven't really seen leaf springs do that other than binding the bushing or twisting the spring.
This post is not intended to convince everyone that our chassis are the only way to go on a resto mod.. But if anyone would like to discuss a little further please message me or give us a call. I'd be happy to lay out the advantages. A big one is that there's barely any floor cutting.. so your interior isn't affected much.
Thanks & have a great day! -Dale Schwartz
Schwartz Performance Inc: The Leader in Bolt-In Muscle Car Chassis for Mopar / Ford / GM. Check out www.MoparChassis.com for our bolt-in Mopar Unibody offerings. We offer products for hundreds of companies including Mopar Performance, Milodon, Billet Specialties, Vintage Air, Stainless Works, Tremec, Silver Sport Transmissions, Forgeline, US Mags, and MANY more!
