ground wire to pcm/ecm? #2587915
12/06/18 02:52 AM
12/06/18 02:52 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
is it needed,is it good practice or just overkill?,02 grand cherokee
my ladder of success is missing some rungs
Re: ground wire to pcm/ecm? [Re: rhad] #2588395
12/07/18 01:32 AM
12/07/18 01:32 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I run a ground wire to all my electrical parts! Probably over kill, but I believe you can't have too many grounds. I'd rather err on the overkill side of things. Its not like its something that is hard or expensive to do. Gene
Re: ground wire to pcm/ecm? [Re: rhad] #2588522
12/07/18 12:09 PM
12/07/18 12:09 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
https://www.amazon.com/Stainless-External-Marine-Bolt-Supply/dp/B071J75LLQ?ref_=fsclp_pl_dp_
I like to use toothed washers like this between the unit and it's mounting surface along with a bit of grease to avoid corrosion They are available at most any hardware store in most any size.
Master, again and still
Re: ground wire to pcm/ecm? [Re: rhad] #2589567
12/09/18 09:00 PM
12/09/18 09:00 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
The case of the pcm does not supply the ground to it, but you wont be doing any harm.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: ground wire to pcm/ecm? [Re: DaveRS23] #2589666
12/10/18 12:42 AM
12/10/18 12:42 AM
None
71rm23 Offline
71rm23  Offline
None
I use the same thing but I also cover it, when done, with women's clear polish they put on nails. Odd but it works
