A-body. 69 dart with stock K and stock disc spindles ... #2586824
12/03/18 11:33 PM
12/03/18 11:33 PM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
.... can I upgrade to a 73 up 16:1 manual box, 73 -76 centerlink and 11/16 tie rods? Any problems? Trying to get better, tighter steering.
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: LAR_414] #2586888
12/04/18 02:25 AM
12/04/18 02:25 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Yes.
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: LAR_414] #2587159
12/04/18 07:44 PM
12/04/18 07:44 PM
AndyF Online content
AndyF  Online Content
You would need to also change the pittman arm and the idler arm since the late style center link is flipped over from the early center link. The tie rods will need to be a different length but you should be able to adjust for that.
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: LAR_414] #2587181
12/04/18 08:46 PM
12/04/18 08:46 PM
LAR_414 Offline OP
LAR_414  Offline OP
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: AndyF] #2587186
12/04/18 09:03 PM
12/04/18 09:03 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
My steering mods are: tubular upper control arms,11/16 tie
rods,reinforced lower control arms,20:1 worm gear.
Firm Feel has a support for the pittman arm and better
option for the idler arm that eliminates the rubber.
I installed those items.
Pretty big improvement.
Mike
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: mkdart] #2587275
12/05/18 12:06 AM
12/05/18 12:06 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
This is going back a long time, but I ended up swapping the later K member out of my 75 Duster into my 68 Barracuda to make it work. This was 15-16 years ago, but I think there was an issue with making the idler work shruggy Just something to keep your eyes out for.
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: LAR_414] #2587484
12/05/18 01:44 PM
12/05/18 01:44 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I believe the idler issues is stud mounting verses through bolt mount. Late 60s is when this change over took place so your '68 idler arm (possible stud mount) may not mount up to the '73 style (through mount) K frame.
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: LAR_414] #2587536
12/05/18 03:17 PM
12/05/18 03:17 PM
I think the conversion from stud to bolt style idler was in 1967. At least it was for the B body cars. So he might be okay. Easy enough to check, just have to open the hood and look down.
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: AndyF] #2587538
12/05/18 03:23 PM
12/05/18 03:23 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Stud ended in 67...
JB Rhinehart, Realist
A-Body's RULE!
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: LAR_414] #2587658
12/05/18 06:28 PM
12/05/18 06:28 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I thought it was '67 but wasn't sure. On a a 42 year old car, anything can be found on occasion and if it is an early production '68, who knows for sure without checking.
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: TC@HP2] #2589038
12/08/18 03:11 PM
12/08/18 03:11 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Just a follow up on my previous comment. No it isn't/wasn't the stud mounted idler. I was working 6 days a week (on OP cars) and trying to swap parts from the '75 Duster to the '68 Barracuda and get ready to move into my home, i.e going through Escrow hell. SO, I really can't remember the specific issue, but there was an issue that precluded a simple idler/pitman/drag link swap. The 'Cuda was P/S and the M/S box was bought here as an unknown source. shruggy
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: LAR_414] #2589058
12/08/18 04:11 PM
12/08/18 04:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
there are two different PITMAN arms depending on manual or power and since your box was unknown source, that may have been what you ran into. The issue was shaft diameter
Don't be the exception.
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: Supercuda] #2589091
12/08/18 06:24 PM
12/08/18 06:24 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That sounds very likely up
Re: A-body. 69 dart with stock K and stock disc spindles ... [Re: LAR_414] #2589577
12/09/18 09:31 PM
12/09/18 09:31 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Early a-body power and manual boxes shared the same pitman arm. Some late manual boxes also had the small sector box, but the power boxes were large sector.
