Re: 727 stator ring issue
[Re: dvw]
#2586725
12/03/18 07:26 PM
12/03/18 07:26 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
What is your line pressure? I was warned by Rick about that when I told him how high I was running my line pressure. I could see those rings being forced outward from pressure. The forward groove most likely gets more splash lube to the groove preventing the forward ring wear. Also may want to check the fit of a new ring inside of the drum on the work bench. Be sure the bore isn’t undersized causing ring butting. Not a trans pro, just my 2 cents.
