Page 2 of 3 1 2 3
Re: 505" stroker carb recommendations [Re: AndyF] #2586613
12/03/18 02:50 PM
12/03/18 02:50 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Originally Posted By AndyF
Originally Posted By GODSCOUNTRY340
Okay, you're running high flowing heads, high flowing intake, high flowing exhaust, 505 cubes. Why restrict everything with that 850 carb? I'd be looking for a 1050 Holley for that beast or that 3916 three barrel as stated above.
Really? You're suggesting the guy put a Dominator carb on a street car? That seems like a bad idea, the guy clearly isn't building a race car and he doesn't have a 4500 intake.
He doesn't need an intake for a 4500, here's a pic of a 1050 that's not a 4500 and will bolt right on his intake.
Re: 505" stroker carb recommendations [Re: GODSCOUNTRY340] #2586622
12/03/18 03:08 PM
12/03/18 03:08 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Reality check here: You cannot compare a 1.58" v x 1.75" t 4150 "1050" with a 1.72" v x 2.0" t 4500 "1050". Doesn't matter what the carb company labels it, it's not an apples-to-apples comparison.
And, yes, I have something like that, too, and it was good enough to make about 680 HP w/ my stock-stroke 440 build. shruggy
Re: 505" stroker carb recommendations [Re: BradH] #2586625
12/03/18 03:13 PM
12/03/18 03:13 PM
BradH Offline
BradH  Offline
Originally Posted By BradH
Car will be street driven with very little trips to the track planned.
Cam?
Converter stall?
Sounds to me like the emphasis should be on drivability, not peak HP potential.
bump < Since I think these answers are still critical to the discussion >
And I agree w/ some other posters above in that it sure doesn't sound like the guy's trying to build a race car. He may have picked some "racy" parts, but that doesn't mean it's what he's expecting the car to be.
Re: 505" stroker carb recommendations [Re: BradH] #2586637
12/03/18 03:27 PM
12/03/18 03:27 PM
Third Stone from the Sun
Scotts72Rallye Offline OP
Thanks for all the responses guys! To be honest my head is spinning right now, LOL! The guy who built the engine for me, although he is Mopar to the bone it doesn't help with his organization skills. frown He can't seem to find the cam card so he's contacting Indy Cylinder head for help. He should hopefully have the cam card info by Wednesday for all the guys who asked what cam is in the motor. He also built the trans and said it's a 9 1/2" converter with 3K stall. Once again thanks for the suggestions guys!!! up
1972 Dodge Challenger Rallye
UNDER CONSTRUCTION
Re: 505" stroker carb recommendations [Re: Scotts72Rallye] #2586645
12/03/18 03:34 PM
12/03/18 03:34 PM
The right foot controls the gas peddle, correct work
My point is you will control how much air the motor sees when driving, the only time you can have a carb. that is to small is at wide open throttle shruggy
I would, and do, buy the biggest carb that I think I might need in a speed contest at the track or on the roads trying tp pass someone work devil
Re: 505" stroker carb recommendations [Re: Cab_Burge] #2586678
12/03/18 05:23 PM
12/03/18 05:23 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I agree with Cab. So why buy a carb that is smaller than the rest of the build?
And there seems to be an implication that a 4500 carb is more of a 'Race' carb. While a 4150 is a 'street' carb. I don't see it that way. The carb should be sized to the needs of the combo and the tune should be for the combo.
Sized right and tuned right, I don't see any preference for a 4500 vs a 4150. It's just how much air the combo wants/needs. A 505" BBM with Max Wedge ports and 6,500RPM potential will need MORE air than most 4150s can supply. Certainly more than an 850.
And tuned properly, they will both have the same street manners.
Master, again and still
Re: 505" stroker carb recommendations [Re: DaveRS23] #2586684
12/03/18 05:36 PM
12/03/18 05:36 PM
BradH Offline
BradH  Offline
IMO, the OP needs to provide a clearer explanation of what his street AND track expectations are for his build. It's really too vague at this point.
Roll with it, guys... nothing else I can add to this discussion. wave
Re: 505" stroker carb recommendations [Re: Scotts72Rallye] #2586694
12/03/18 05:59 PM
12/03/18 05:59 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Go EFI and be done with it.
OK - I'll go away now. No offense intended.
Re: 505" stroker carb recommendations [Re: Scotts72Rallye] #2586701
12/03/18 06:27 PM
12/03/18 06:27 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
"max wedge intake"
OE max wedge intake=crossram
Based on other comments, it's not a crossram....
What is it?
Rich H.
Esse Quam Videri
Re: 505" stroker carb recommendations [Re: Rob C] #2586706
12/03/18 06:48 PM
12/03/18 06:48 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
Originally Posted By Rob C
IDK fellas. Street driven w/3.55’s no matter what is upstairs is a car with long legs.
How often is the car running above 4500 @ WOT? The OP even said he is driving the street.
I believe the 850 would be a good compromise and still yet deliver.
You all can bla bla bla about what is being left on the table but I don’t see the OP chasing max power and every last pony possible.
This is basically my take on it as well.
I’m going to assume the intake manifold is either a 440-2, 440-2D, or MP 337.
I’d use either a QFT SQ-850 or 950.
Re: 505" stroker carb recommendations [Re: fast68plymouth] #2586763
12/03/18 09:06 PM
12/03/18 09:06 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
What's the difference between a QFT Q and a QFT SQ? confused
Re: 505" stroker carb recommendations [Re: Scotts72Rallye] #2586786
12/03/18 09:54 PM
12/03/18 09:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
SQ is “Street Q”.
Less billet stuff, less racy calibration.
Re: 505" stroker carb recommendations [Re: ZIPPY] #2586871
12/04/18 01:47 AM
12/04/18 01:47 AM
Originally Posted By ZIPPY
"max wedge intake"
What is it?
Sorry about that, it's the Indy intake with max wedge ports that came with the Indy EZ-1 head kit. Not sure of the exact model number, still waiting for more info on that from the builder.
UNDER CONSTRUCTION
Re: 505" stroker carb recommendations [Re: BradH] #2586875
12/04/18 01:53 AM
12/04/18 01:53 AM
My exact words to the engine builder were "I don't want some kid in a Subaru pulling up beside me at a stop light and kicking my azz! If it runs high 10's/low 11's in the 1/4 I'll be happy". I gave the builder complete control of the build to make that happen.
UNDER CONSTRUCTION
Re: 505" stroker carb recommendations [Re: Scotts72Rallye] #2586897
12/04/18 02:48 AM
12/04/18 02:48 AM
BradH Offline
BradH  Offline
I have no idea what you're used to driving. Have you owned or driven a legit high 10 / low 11 sec street car before (one with the ET slips to verify it)?
Re: 505" stroker carb recommendations [Re: BradH] #2586949
12/04/18 10:39 AM
12/04/18 10:39 AM
I've owned my Challenger for 33 years. up Never driven a "legit high 10/ low 11 sec street car". frown Trying to get there, what carb would you recommend BradH?
UNDER CONSTRUCTION
Re: 505" stroker carb recommendations [Re: BradH] #2586960
12/04/18 11:07 AM
12/04/18 11:07 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
more people who are building these things should ask themselves these questions! can the owner handle the power? can the owner tune/maintain the car?
Re: 505" stroker carb recommendations [Re: lewtot184] #2587020
12/04/18 02:06 PM
12/04/18 02:06 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
If it runs that strong, I hope you will be very careful getting used to it. I went from a mid 11 second street car to a 10 second car and there was a bit of a learning curve there, especially when jumping into it on public streets. I finally went to MT ET streets because if you hit it just a bit to hard to pass, it would get loose. This is not meant to be condescending in any way, and I am sure that is what Brad is getting at. As far as a carb goes, I think any of the quality carbs mentioned in a 950 would balance your need for power and streetability. You could always get a larger carb later, if needed. You have to find a balance for your expectations. I built a nice 493 for a friend with a Holley HP 950 and he loves it as he drives it on the street 99% of the time. Lots of good advice here and good luck!
Re: 505" stroker carb recommendations [Re: Mopar_Rich] #2587024
12/04/18 02:12 PM
12/04/18 02:12 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
How about the miracle Fish Carburetor?
Keep old mopars alive.
Re: 505" stroker carb recommendations [Re: Scotts72Rallye] #2587031
12/04/18 02:36 PM
12/04/18 02:36 PM
BradH Offline
BradH  Offline
Sorry, more questions:
1. What's in it now?
2. How fast is it today, or -- as in my own case -- the last time it ran? whistling
3. What's the fastest / quickest muscle car you've ever driven, and was this on the street or the strip?
4. What's going to make you happier, a quick ET slip, or not having to mess with the car on a regular basis?
5. Have you received the cam specs, yet? Any idea if it's a solid or hydraulic, flat-tappet or roller?
6. Done much carb & ignition tuning before?
7. Is fuel mileage any concern at all? How does 8 MPG sound?
8. Are you interested in trading off some amount of performance for better behavior (less "fussy") in normal street driving?
9. How much time have you spent ON (not AT) a drag strip?
10. If you have 11-second MPH, but 13-second ETs because the car doesn't "work" well at the track (spins, instead of hooks up), are you going to leave it as it is, or start to get more $eriou$ about chassis tuning and on-track testing?
11. How far do you expect to drive the car on the street, and is there much highway time in your plans?
12. If/when you go to the track, are you driving the car there, or trailering it?
13. If a 9-sec Subaru WRX cuts your nutz off in a race, can your ego (and/or bank account) handle it? laugh2
14. What does your engine builder say he thinks you should run for a carb? And if you choose to run something different, is that going to p!ss him off?
Page 2 of 3 1 2 3
