Page 5 of 5 1 2 3 4 5
Re: Vic 340 build [Re: Biginchmopar] #2585360
11/30/18 09:16 PM
11/30/18 09:16 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Stop by T&S Machine at PRI to see this beast in person.
Will have a head to look at also.
Re: Vic 340 build [Re: W5DART66] #2585402
11/30/18 10:43 PM
11/30/18 10:43 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Incredible build by all involved! Nice!
Re: Vic 340 build [Re: W5DART66] #2585554
12/01/18 05:04 AM
12/01/18 05:04 AM
SoCal
Brian Hafliger Offline
SoCal
Hangin' with Tim and the boys?? Sounds like fun! Tell him Hi.
Brian Hafliger
Re: Vic 340 build [Re: Biginchmopar] #2585633
12/01/18 01:54 PM
12/01/18 01:54 PM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
Originally Posted By Biginchmopar
Imagine that bullet in a pipe rack shock haha
Does anyone know that this beast is going into?
Re: Vic 340 build [Re: 340Cuda] #2585871
12/01/18 11:02 PM
12/01/18 11:02 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
what's the maintenance on a motor like that?
Awesome job!!
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Vic 340 build [Re: Stroker Scamp] #2585909
12/02/18 12:43 AM
12/02/18 12:43 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Really maintenance would not be bad on this at all.
Shift at 8500 I am not sure how many passes it would go before it might need springs.
Has 65 pulls on the dyno between 8500 and 9000 rpm.
Springs still check fine.
Rocker ratio only 1.8 intake exhaust 1.75
60mm cam and Jesel keyway lifters are solid parts and should give good service life.
Re: Vic 340 build [Re: W5DART66] #2585912
12/02/18 12:50 AM
12/02/18 12:50 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Awesome build Brett as usual. How did you come up with the extinct r3 block?
Re: Vic 340 build [Re: rickraw] #2586106
12/02/18 02:01 PM
12/02/18 02:01 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Got it 3 or so years ago for a guy doing turbo build.
Was in NJ was on eBay
Funny was sold 2 times after that and it's back here and I got to build it 🙃
Re: Vic 340 build [Re: W5DART66] #2588952
12/08/18 04:29 AM
12/08/18 04:29 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I was on the Edelbrock stand, it was today or yesterday. One of the Edelbrock guys was showing Herb McCandless around, made a point of showing Herb Brett's ported head. Really talked up the good results and Brett's hard work, and what might happen in the future. Just thought I'd mention it
Alan Jones
Re: Vic 340 build [Re: LA360] #2589110
12/08/18 07:57 PM
12/08/18 07:57 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
That's cool to hear.
Did you get to check head out ?
Did you get to see the engine ?
Sorry we did not catch up.
Re: Vic 340 build [Re: W5DART66] #2589332
12/09/18 01:47 PM
12/09/18 01:47 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
Brett, do you and the Hartzmans have a plan to modify and market these heads in quantity?
Re: Vic 340 build [Re: W5DART66] #2589367
12/09/18 02:40 PM
12/09/18 02:40 PM
LA360 Offline
LA360  Offline
There were a few guys I missed,I'll be back at some point.
I went by and checked out your handy work on a few occasions over the three days of the show. I will be telling a good friend about what you're achieving, he's got a few Victor headed engines almost finished. Hopefully I'll convince him to run something with a decent port on his next customers build.
Alan Jones
Re: Vic 340 build [Re: W5DART66] #2589370
12/09/18 02:48 PM
12/09/18 02:48 PM
p.a.
420duster Offline
420duster  Offline
p.a.
Brett, I might’ve missed it...what compression does this motor have ?
Re: Vic 340 build [Re: 340Cuda] #2589380
12/09/18 02:59 PM
12/09/18 02:59 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Lenny Knott the CNC machine owner that is cutting the heads has 8 sets on order RAW castings.
This will help us make the changes we want to with out having to fix/re-do what was machined.
The heads will have HIP process done on them also.
When they are ready to go I am sure we will do a group buy or something to get them out into the market.
Re: Vic 340 build [Re: 420duster] #2589381
12/09/18 02:59 PM
12/09/18 02:59 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Did not post that info.
Re: Vic 340 build [Re: W5DART66] #2612303
01/25/19 10:29 PM
01/25/19 10:29 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I see your header tubes are in firing order sequence. People are always arguing if it is worth it. I've always believed it helps. Have you noticed much power differences with header primaries that aren't in firing order?
