5.7 and 6.1 oil pumps, how to tell the difference? #2585718
12/01/18 04:36 PM
12/01/18 04:36 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
Any easy way to tell the difference of both pumps by a casting number or other marking? Looks like they have 1622 on them then a 6 7 8 etc beside that. Putting my 6.1 back together and want to use the right pump.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 5.7 and 6.1 oil pumps, how to tell the difference? [Re: Silver70] #2585918
12/02/18 01:06 AM
12/02/18 01:06 AM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
Found out the difference is just the spring and the metal retainer cup is where the spring used is stamped. Anyone out there has a 6.1 pump sitting around they can check the number stamped on the bottom metal retainer?
Re: 5.7 and 6.1 oil pumps, how to tell the difference? [Re: Silver70] #2586025
12/02/18 09:10 AM
12/02/18 09:10 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
the only 6.1 Pump I have here at work has a 2 stamped in to it.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 5.7 and 6.1 oil pumps, how to tell the difference? [Re: Silver70] #2586235
12/02/18 06:30 PM
12/02/18 06:30 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
Is that the bottom plug, pump I have has a 3 on bottom, then plug on top going more horizontal has a 2.
