Ok, the trans is built and the valve body modified with a Fairbanks shift kit which looks to be the same as as a B&M and a TCI kit. The plan is to go full manual so I've done all the mods to suit but the instructions are a little vague on how to set up throttle pressure valve. I know with the Transgo kit it gets you tie back the kickdown to get full pressure on shifts but not sure about the Fairbanks set up.
[url=https://static.summitracing.com/global/images/instructions/tci-220000.pdf][/url] Fig.24 is the instruction.
I have installed the red spring and the throttle valve protrudes out a fair bit. This is how i have it set up at the moment.
