poly trans mt good idea or not?
#2584258
11/28/18 04:43 PM
11/28/18 04:43 PM
RapidRobert
circle track (on/off throttle) early Dart 360/904. & also with or with out solid eng mts (one or both sides?). thank you for your time.
Re: poly trans mt good idea or not?
[Re: RapidRobert]
#2584265
11/28/18 05:15 PM
11/28/18 05:15 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I use a poly trans mount on my cuda w/ a front motorplate. Same trans mount has been on it for 20 years now.
[Re: RapidRobert]
#2584349
11/28/18 08:24 PM
11/28/18 08:24 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
Poly mount in my Charger.
[Re: CSK]
#2584399
11/28/18 09:55 PM
11/28/18 09:55 PM
RapidRobert
Unanimous, that's good to hear cuz I decided I "wanted" one (& have it) as opposed to checking with you guys first to see if I "needed" one. Thanks guys.
[Re: RapidRobert]
#2584621
11/29/18 12:17 PM
11/29/18 12:17 PM
Posts: 22,696 Bitopia
jcc
Bitopia
1. I also have one 2. I can't convince myself what the real upside is, other then looks, in this application 3. Poly sucks as far as longevity and when it decides to suddenly disintegrate without warning
[Re: RapidRobert]
#2584716
11/29/18 03:22 PM
11/29/18 03:22 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Been running one in my drag car with a transbrak several years with no issues.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: RapidRobert]
#2585290
11/30/18 06:38 PM
11/30/18 06:38 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
My 65 B body I run poly on all 3 mounts with BB 4 speed.My kid ran all 3 in his 62 300 also.Never a problem.We git them from Steve at Imperial Services.Both motor mount sets were protypes.Same with the 62 tranny mount.Both have been in at least 12 years or more.Rocky
Chrysler Firepower
[Re: therocks]
#2585300
11/30/18 06:51 PM
11/30/18 06:51 PM
RapidRobert
Early A ('64) with SB. I have the poly trans mt (it looked too purty to pass up!) & I'm wondering if I should go solid on the eng (I ain't thinking a solid is available for em) but I could lock em solid on one or both sides?
[Re: RapidRobert]
#2585604
12/01/18 12:27 PM
12/01/18 12:27 PM
therocks
Niles , Ohio
Typicall y just the DS needs a solid or locked mount.My 65 I would tear the DS easy.Even the old OE mounts would tear.Put polys in and no more trouble.Rocky
Chrysler Firepower
[Re: LAD 524]
#2585957
12/02/18 02:40 AM
12/02/18 02:40 AM
RapidRobert
Is the eng plate mounted solid to the (sub)frames? It sounds like it is (& from others who have it) from the jist of this but I did see a pic of one once that was set down on rubber biscuits on each subframe with L brackets on each end.
[Re: RapidRobert]
#2586005
12/02/18 05:29 AM
12/02/18 05:29 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I have one in my street car and there is noticeable vibration when I swapped it in... but nothing that bad.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: RapidRobert]
#2586517
12/03/18 12:00 PM
12/03/18 12:00 PM
an8sec70cuda
Is the eng plate mounted solid to the (sub)frames? It sounds like it is (& from others who have it) from the jist of this but I did see a pic of one once that was set down on rubber biscuits on each subframe with L brackets on each end. An engine plate is typically solid mounted to the frame rails. Some pro touring type of builds use some rubber mounts on them varying in designs.
[Re: an8sec70cuda]
#2586608
12/03/18 02:40 PM
12/03/18 02:40 PM
RapidRobert
^^^ noted, & it sounds like solid mts on both sides will not be an issue. Thanks guys.
