Re: Correct color black for k frame and rear end?
[Re: 79machocharger]
#2584886
11/29/18 10:08 PM
11/29/18 10:08 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
It was gloss black. The sheen varies by the day of the week, weather, who was painting, how they mixed the paint, temperature, gun they used, whether the Lions, Pistons, Tigers lost yesterday, you name it.
At the end of the day it was supposed to be gloss black
#2584925
11/29/18 11:09 PM
11/29/18 11:09 PM
Morty426
Sacramento CA
I’m trying to this as correctly as I can. It’ll be back from getting blasted tomorrow along with k frame. I assume k frame was done the same. Yes K frame is the same
#2584932
11/29/18 11:21 PM
11/29/18 11:21 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
I like Eastwoods Chassis black....
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
#2585138
11/30/18 12:52 PM
11/30/18 12:52 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
I have found that the SEM Chassis black matches as close as possible. I have usually had the k-frame powder coated since it can get oil and gas ext. on it. Gloss with a slight bit of dullness to it. I also have found that the Eastwood chassis black is more flat like would be on a Chevy.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#2585245
11/30/18 04:20 PM
11/30/18 04:20 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
I also have found that the Eastwood chassis black is more flat like would be on a Chevy. Eastwood's chassis black comes in satin and gloss. I suspect you are referring to the satin finish as it does appear somewhat flat. The gloss version definitely is not flat.
1968 Charger R/T, 440 Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
[Re: ScottSmith_Harms]
#2585422
11/30/18 11:00 PM
11/30/18 11:00 PM
Morty426
Sacramento CA
Want it correct or beautiful? If you want it correct go buy the cheapest gloss black paint money can buy and blast it on without much regard to anything (neatness, conditions, etc.). Ultra cheap gloss paint (think tractor supply) usually dulls back all by itself so no flattening agents required. I would recommend using a catalyzed paint and that you apply with a paint gun as opposed to rattle cans as it will hold up much longer if catalyzed.
.02 It also helps if you consume a 1/5 of Vodka before spraying it and dilute the paint and increase the air pressure so you can spray it from two feet away - should get you the right look
#2585727
12/01/18 04:47 PM
12/01/18 04:47 PM
Morty426
Sacramento CA
Ended up getting a nason single stage gloss black fast dry. Should be able to use it on the seat brackets, torsion bars, and leaf springs. Did t/a’s have black leaf springs or natural. Thanks for the help Leafs can be either way. You have to take yours apart to see what evidence you can find. BTW - are you keeping the 450s on the car? (I hope so)
