Correct color black for k frame and rear end? #2584881
11/29/18 09:58 PM
11/29/18 09:58 PM
ME
79machocharger Offline OP
ME
Looking for the right color black for rear end and k frame. Is it a gloss black with some flatening agent.
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2584882
11/29/18 10:00 PM
11/29/18 10:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Black is the color.
Sheen / gloss level varies for any color & applications too.
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2584886
11/29/18 10:08 PM
11/29/18 10:08 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It was gloss black. The sheen varies by the day of the week, weather, who was painting, how they mixed the paint, temperature, gun they used, whether the Lions, Pistons, Tigers lost yesterday, you name it.
At the end of the day it was supposed to be gloss black
Re: Correct color black for k frame and rear end? [Re: Alaskan_TA] #2584888
11/29/18 10:12 PM
11/29/18 10:12 PM
ME
ME
It for a 1970 b5 blue challenger Ta I’m restoring
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2584889
11/29/18 10:15 PM
11/29/18 10:15 PM
ME
ME
I’m trying to this as correctly as I can. It’ll be back from getting blasted tomorrow along with k frame. I assume k frame was done the same.
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2584898
11/29/18 10:31 PM
11/29/18 10:31 PM
ME
ME
Car will be heading down to be blasted monday
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2584925
11/29/18 11:09 PM
11/29/18 11:09 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yes K frame is the same
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2584932
11/29/18 11:21 PM
11/29/18 11:21 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
I like Eastwoods Chassis black....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2585005
11/30/18 01:52 AM
11/30/18 01:52 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Want it correct or beautiful? If you want it correct go buy the cheapest gloss black paint money can buy and blast it on without much regard to anything (neatness, conditions, etc.). Ultra cheap gloss paint (think tractor supply) usually dulls back all by itself so no flattening agents required. I would recommend using a catalyzed paint and that you apply with a paint gun as opposed to rattle cans as it will hold up much longer if catalyzed.
.02
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2585059
11/30/18 09:05 AM
11/30/18 09:05 AM
ME
ME
thanks guys appreciate your info. I’ve done many cars in the past and my cars have been nice driver type cars with the exception of the 71 hemi Cuda concertible I helped my brother with a few years back. Now I’m going to be doing this as a living. I’ve always done this as a hobbie and have had some really neat cars along the way. These cars are in my blood and I’m really excited about working on theme every day. I’ll be on here and other sites a lot more often now gathering info for this Ta build.
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2585138
11/30/18 12:52 PM
11/30/18 12:52 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I have found that the SEM Chassis black matches as close as possible. I have usually had the k-frame powder coated since it can get oil and gas ext. on it. Gloss with a slight bit of dullness to it. I also have found that the Eastwood chassis black is more flat like would be on a Chevy.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Correct color black for k frame and rear end? [Re: MOPARMIKE69] #2585245
11/30/18 04:20 PM
11/30/18 04:20 PM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
Eastwood's chassis black comes in satin and gloss. I suspect you are referring to the satin finish as it does appear somewhat flat. The gloss version definitely is not flat.
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: Correct color black for k frame and rear end? [Re: ScottSmith_Harms] #2585422
11/30/18 11:00 PM
11/30/18 11:00 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
.02
It also helps if you consume a 1/5 of Vodka before spraying it and dilute the paint and increase the air pressure so you can spray it from two feet away - should get you the right look
Re: Correct color black for k frame and rear end? [Re: Morty426] #2585447
11/30/18 11:48 PM
11/30/18 11:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I was going to say Rum, but yea, that's it Morty! laugh2
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2585452
11/30/18 11:49 PM
11/30/18 11:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Also Macho, in case you were not aware, the center section is not painted at all, it's bare cast iron.
Re: Correct color black for k frame and rear end? [Re: ScottSmith_Harms] #2585560
12/01/18 06:54 AM
12/01/18 06:54 AM
ME
ME
Great info thanks guys. Just picked them up and plan on working on them next week.
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2585699
12/01/18 03:57 PM
12/01/18 03:57 PM
ME
ME
Ended up getting a nason single stage gloss black fast dry. Should be able to use it on the seat brackets, torsion bars, and leaf springs. Did t/a’s have black leaf springs or natural. Thanks for the help
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2585727
12/01/18 04:47 PM
12/01/18 04:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Leafs can be either way. You have to take yours apart to see what evidence you can find.
BTW - are you keeping the 450s on the car? (I hope so)
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2585734
12/01/18 05:02 PM
12/01/18 05:02 PM
ME
ME
Yes
Re: Correct color black for k frame and rear end? [Re: 79machocharger] #2585797
12/01/18 07:36 PM
12/01/18 07:36 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yes
Wise choice up
