Vacuum Advance question
#2584733
11/29/18 03:50 PM
11/29/18 03:50 PM
Posts: 114 Oklahoma City, Oklahoma
MrMayhem
So I just picked up a nice 72 Duster with a 440 swap (unknown internals) Seems to have what sounds like a 280-ish advertised duration cam, Holley Street Dominator intake and an Edelbrock carb. Bottom end is said to have flat tops and 452 heads.
First thing first the car needs some tuning as it has a nasty stumble on the bottom end (lean I think) and I noticed the Vacuum advance is not hooked up.
With the vacuum adv. not connected to a vacuum source, does is it run at full advance all the time or is it retarded all the time?
I have only had the car in my possession for less than 36 hours so I have lots to learn about it. Long term, I'll build a 512 for it that will be a bit more hot street orientated but for now I just want to get this thing running better with the parts that are bolted to it.
Thanks in advance
Re: Vacuum Advance question
[Re: MrMayhem]
#2584739
11/29/18 04:02 PM
11/29/18 04:02 PM
RapidRobert
No vac line to the can= no vac adv. check for an immediate/adequate squirt when the throttle is moved (tip in). what is your initial (manifold or ported?). Wouldn't hurt to do a compression test just for a baseline to go in your notes. what is your idle speed? (in gear if auto). that'll get us started.
[Re: MrMayhem]
#2584744
11/29/18 04:11 PM
11/29/18 04:11 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
280ish cam? I wouldn't even try to use it. And I would limit the potential total of the mechanical advance as well.
[Re: MrMayhem]
#2584778
11/29/18 05:15 PM
11/29/18 05:15 PM
crabman173
crabman173
Get a advance limit plate from FBO and follow instructions--will make a new ride out of it They are great folks and KNOW hwat to do to help
[Re: MrMayhem]
#2584779
11/29/18 05:18 PM
11/29/18 05:18 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
If you're going to drive on the street (i.e. not WOT all the time) then you need vacuum advance! A "280-ish" cam should have plenty of idle and cruise vacuum. My 383 with a 284/.484 idled at 13" for example. What we don't know is what kind of mechanical advance you have. Or even what the initial timing is set to. If it's a stock distributor (26+ crank degrees mech advance) then the previous owner probably disconnected the vac advance can to keep it from pinging with the initial advance required for a decent idle. I recommend you put a timing tape on the damper, and verify TDC is really at the 0 mark too. Then hook up a light and see what you've got as a starting point, before you start making changes blindly. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: ]
#2584794
11/29/18 06:02 PM
11/29/18 06:02 PM
Posts: 403 Colorado front range
BcudaChris
Get a advance limit plate from FBO and follow instructions--will make a new ride out of it They are great folks and KNOW hwat to do to help X2 on this advice, once you know for sure what is going on. In Mopar cast distributors, that plate is the easiest method I know to limit advance to the range your engine needs. Be aware though, there are two theories on vac advance, timed port v. constant port. FBO is a proponent of constant, which in my case gives me about 30*@ idle. Works very well for me, but all FBO support is going to be under the assumption that you are running advance from a constant vac port. Obviously, both work. More than one way to skin a cat.
[Re: MrMayhem]
#2584810
11/29/18 07:03 PM
11/29/18 07:03 PM
MrMayhem
Well for the $25 bucks I ordered the FBO part... I do need to buy a timing light. My 30 year old piece of crap don't work any longer. Does anyone have suggestions on a decent budget minded Timing light?
[Re: DrCharles]
#2584814
11/29/18 07:20 PM
11/29/18 07:20 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
I recommend you put a timing tape on the damper, and verify TDC is really at the 0 mark too. Then hook up a light and see what you've got as a starting point, before you start making changes blindly. ^^^This what you should do first.^^^^ If there is a tag on the distributor, that will be a clue as to how it started life. But that doesn't tell where its at now. Krautrock's explanation of what vacuum advance does is pretty much it. If the first stage of the mechanical advance in the distributor is long and fast, don't use the FBO plate. Weld up the inside of the slots (assuming its a distributor with Chrysler guts in it).
[Re: MrMayhem]
#2584824
11/29/18 07:38 PM
11/29/18 07:38 PM
Mattax
Phila. Pa.
With timing tape you can use any ole timing light that you like. You'll also need a tachometer.
Identify what it has for ignition, Points, dual point, Chrysler electronic or something else.
On the carburetor, go through all of the basics first. Fuel level, does the choke open properly Check that fuel squirts out of the shooters when the throttle is opened. At hot idle, does turning the idle mixture screws in effect rpm. if so, make 'em a 1/8 to 1/4 turn richer (ccw) than when engine slows while turning them in. Then see if the stumble occur in N, in gear or both.
before or after going over the basic carb checks Look at the spark plugs for obvious clues. At minimum check initial timing. if a points ignition, check their condition.
[Re: MrMayhem]
#2584825
11/29/18 07:40 PM
11/29/18 07:40 PM
Mattax
Phila. Pa.
It is a chryco dist. I'll check the tag on it tonight. Can you explain your weld up mod in more detail? What are is the result of doing so? Sorry you posted while I was typing. Mopar performance sold a chrysler distributer with Mallory advance mechanism for about 10 years. Too your question. Yes. Give me a few minutes to wrap up some stuff first.
[Re: Mattax]
#2584826
11/29/18 07:43 PM
11/29/18 07:43 PM
Posts: 4,701 Wichita
GY3
Wichita
Here is what I do, and have always done with all my BB Mopars:
I rebuild a regular Chrysler magnetic pickup distributor. I put in Mr. Gasket #925B lightweight springs. I set the total mechanical advance at 34-36° and never hook up the vacuum advance.
My cars idle, run and drive perfect. I get up to 11mpg out of my 505 with 3.54 gears going 70 mph down the highway.
I have installed an analog MSD timing controller on my MSD box and plan on upping the total timing on the one road trip I do with it every year to see if there is a mileage difference.
[Re: MrMayhem]
#2584845
11/29/18 08:28 PM
11/29/18 08:28 PM
Mattax
Phila. Pa.
Can you explain your weld up mod in more detail? What are is the result of doing so? The advance weights have a pin that rides in slot. The length of the slot determines the amount of advance possible. The maximumn amount that can be advanced can be reduced by shortening the slots. Welding is one way to make the slots shorter. Here's a plate with 30 advance degrees in the slots welded up in the inside for less advance. Then a little filing to make both slots the same. Notice when its installed that the primary spring has more tension on it. Similarly, the weight with the long looped secondary spring has less distance to travel before it is restrained by that spring. This is generally what we want when running for best efficiency (powerwise) and a vacuum advance. Note: This is a smallblock distributor
[Re: MrMayhem]
#2584901
11/29/18 10:40 PM
11/29/18 10:40 PM
Posts: 4,210 New York
polyspheric
New York
Both are right. Everything is right. They're both the same. All fixed!
Boffin Emeritus
