Re: Engine building: using cheaper parts?
[Re: DGS]
#2584609
11/29/18 11:32 AM
11/29/18 11:32 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
If APPROPRIATE in your build one example would be hypereutectic cast piston instead of the forged piston. They are less expensive than forged yet high quality. Must be application correct though. A hyd flat tappet cam is over a grand cheaper than going Hyd Roller (Unless you already own parts for a hyd roller set up) but I HATE all the stories of Hyd flat tappet cam/lifter failures. Used intake manifolds generally are a bargain and safe. Factory remanned carbs sadly do not offer significant savings over new- at least with Edelbrock. The old reliable stand by of cast iron piston rings are very affordable but Moly rings offer so much more for the money they have become the modern gold standard. That's all I can think of. I'm assuming your re using an OEM crank and rods. ARP bolts are kinda the standard as they are great quality but there are some less expensive rod bolts like Pioneer.
Keep old mopars alive.
[Re: DGS]
#2584654
11/29/18 01:19 PM
11/29/18 01:19 PM
DaytonaTurbo
Manitoba, Canada
IIRC, once upon a time there were some cooling issues with the off shore water pump houings, but to be fair there's nothing really wrong with an oem water pump housing. How much lighter is an aluminum housing, like 3 pounds? I can lose a lot more than that off my stomach!
Rockers are ok to cheap out if you use stock rockers and a hydraulic flat tappet cam mild enough to work with stock rockers. That can save a lot of dough over a roller cam with adjustable rockers. I've used a 440 source oil pan and pickup without problem, as well as their cylinder heads. I would use one of their balancers on a street/strip engine. Cheap headers work, although their fit and finish can require a bit of finessing. Like 2bolt said, used intakes are a good option, carbs can be hit or miss. Cheap distributors work, but are usually limited on their adjustabilty and tech support.
[Re: DGS]
#2584677
11/29/18 02:07 PM
11/29/18 02:07 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Depends on what you are expecting out of your build. Strictly street, no racing, just a to and from build... cheap will work. Some street racing, or an occasional trip to the track... rotating assembly would not be the place to cheap out. Anything more severe than that... buy quality parts.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: DGS]
#2584731
11/29/18 03:45 PM
11/29/18 03:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Man it really depends.
If it's a stock type rebuild or even mild upgrade, just reuse the stock stuff if it's good. You do not need anything fancy, note I said NEED.
Lot's of people get caught up in name dropping. Who cares in the end.
Before you replace any stock part with something an aftermarket piece ask yourself "why do I need this part?" If it's because it's chrome and you like chrome, whatever. But if it's because it's just a name then forget it.
The stock Thermoquad runs fine and is very tuneable, but too many get caught up in names. It's real funny when someone says "it's got a Holley Double Pumper" and you look and see a Carter BBS.
Or camel hump heads and it's a v6, lol. Or a short shifter and it's an automatic.
IOW, sorry for the tangent, don't do something because "everyone is doing it". Do something because you need it and you know why you need it,
[Re: DGS]
#2584911
11/29/18 10:54 PM
11/29/18 10:54 PM
Posts: 43,181 Bend,OR USA
Cab_Burge
[Re: DGS]
#2584927
11/29/18 11:11 PM
11/29/18 11:11 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
In every other thread it is recommended to not cheap out on this or that (rocker arms, balancers etc.) but where is it ok (for you) to use cheaper parts? I have bought almost all parts for my build so this question is just out of curiosity. Things that come to my mind are: water pump housing, oil pan, valve covers (as you can see none of these parts are essential for making power). What power level? If 450 hp or less, I wouldn't even replace any of the items on your list if the budget is tight. I wouldn't buy a fastener either unless you are missing them. I've never had a factory original oil pump not meet the oil demand for a stockish rebuild.
[Re: Cab_Burge]
#2584944
11/29/18 11:47 PM
11/29/18 11:47 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
On your valve cover issue Cab, have you considered machining the valve cover rail on the head? My local MW guru used to have that problem until he laid a straight edge on the rails and discovered they were nowhere close to true. A trip thru the milling machine and no more leaks or warped covers. All his iron Mopar heads get this procedure now. Kevin
[Re: DGS]
#2584974
11/30/18 12:32 AM
11/30/18 12:32 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Then DO not build a HEMI...nothing cheap there.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Twostick]
#2585000
11/30/18 01:24 AM
11/30/18 01:24 AM
Cab_Burge
Edlebrock RPM heads that didn't leak before Murphy hates me they are flat also but the sealing surface is real narrow, any one else having leaking issues with their chrome steel Milidon BB V.C.?
[Re: DGS]
#2585496
12/01/18 01:23 AM
12/01/18 01:23 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Fab aluminum cover are chinese cheap but they work with the thick mounting rail! I went bling with polished covers,or you paint them if you wish.
[Re: DGS]
#2585523
12/01/18 02:26 AM
12/01/18 02:26 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
How good are the off brand carbs like summit? And intakes?
Have a great day Iowan
"obsolete is neat"
[Re: Iowan]
#2585807
12/01/18 08:01 PM
12/01/18 08:01 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I would look into Wiseco Pro-Tru pistons. I have a set in my 493 and they are much like a full race piston but are about $300 cheaper. I use the Summit brand smooth cast valvecovers with Superformance gaskets. The Mancini water pump kit is a good value except the chrome t-stat housing. I would stay away from any roller rocker for a street car but Mancini used to offer a bushed Harlan Sharp rockers that would make an excellent street rocker. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: DGS]
#2585936
12/02/18 01:43 AM
12/02/18 01:43 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
external parts that are easy to replace and do not require machine work. If you build a good strong short block, it makes the basis for all other mods. Heads and cam should be in mind to choose the correct pistons for compression ratio. Stuff like intake, carb, water pump, cooling, exhaust system can be upgraded when money allows. In the past I was sometimes cheap on safety parts. Good insurance to not be cheap on dampner, flexplate, converter, A@A Super Sprag and billet drum. Highly recommend driveshaft loop at a minimum.
[Re: DGS]
#2586040
12/02/18 11:17 AM
12/02/18 11:17 AM
Posts: 3,916 usa
lewtot184
usa
I ended up using the summit $34 chrome valve covers on my edelbrock heads. stock stuff wouldn't fit. the summits have a heavier construction and seal great.
I don't think i'd consider 550-600hp build to be in the "cheap zone". use good parts.
[Re: 451Mopar]
#2588649
12/07/18 04:02 PM
12/07/18 04:02 PM
Posts: 19,406 north of coder
moparx
Good quote I read: “There's never enough time (or money) to do it right, but there's always enough time (or money) to do it over.” – Jack Bergman. and the one we used at work. "if it ain't broke, keep fixin' it 'till it is !"
