Anyone rebuild A12 hex head idle solenoid
#258445
03/18/09 08:14 PM
03/18/09 08:14 PM
my original hex head delco remy idle solenoid has no pop to it and wont go up on its own. does anyone rebuild these since i want to keep the original barrel and hex head, can a repop one be interchanged to the original barrel or can this one be repaired? any help greatly appreciated
Re: Anyone rebuild A12 hex head idle solenoid
#258446
03/18/09 08:15 PM
03/18/09 08:15 PM
Posts: 21,428 It's a dry heat
gtx6970
It's a dry heat
[Re: gtx6970]
#258447
03/18/09 08:21 PM
03/18/09 08:21 PM
Scott Smith, email sent thanks
[Re: Snoopy]
#258450
03/18/09 11:25 PM
03/18/09 11:25 PM
Posts: 400 Soldotna,Alaska
RT_6_PakShaker
super street
super street
Soldotna,Alaska
Scott, Have you tried to transplant the guts from one of the reproduction units or one of the other Delco solenoids?
Snoopy That's how I have rebuilt the half dozen or so that I have done, pretty easy to do.
[Re: RT_6_PakShaker]
#258453
03/19/09 07:23 AM
03/19/09 07:23 AM
any chance you'd like to attempt to fix mine for me.ill pay dearly
#258454
03/19/09 09:25 AM
03/19/09 09:25 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Some of the aftermarket ones I have done have a larger ring on the inside top of the housing and the coil from one won't seat far enough to crimp the retainer.The O.E.M. coil is 1 3/4. I have a few aftermarket coils that are 1/4" shorter.Another thing I noticed is that the spade connectors are different on some .The complete solenoid is a O.E.M. Dr1114429,the coil is from a DR1114420.Also O.E.M.
[Re: A12]
#258455
03/19/09 09:37 AM
03/19/09 09:37 AM
62maxwgn
Blair County,PA
Is there a specified "throw" of the original plunger or does that even make a difference. I would think it would but only if you are using factory tuning procedures (see 1969 Master Tech "Performance" article for example adjustment). Don't solenoids vary in throw and not all are the same? I know there were two differen "throws" for my diesel starter solenoid and had to make sure I got the correct one. Just asking?
MikeR
Mike,the throw of the solenoid is adjustable.The plunger is threaded into the solenoid weight in the coil.
[Re: 62maxwgn]
#258456
03/19/09 09:46 AM
03/19/09 09:46 AM
Posts: 21,507 N.E. OHIO, USA
A12
N.E. OHIO, USA
MikeR
Bill thanks, but with the "contact" being adjustable does the throw or distance the solenoid travels actually change? Kind of like crankshaft stroke doesn't change with longer or shorter connecting rods.....probably wrong again sorry for that
MikeR
