493 build #2583918
11/27/18 10:52 PM
11/27/18 10:52 PM
WV
WV Runner Offline OP
WV
I'm putting together a 493 stroker. 10.5:1 compression, indy ez heads, mopar single plane intake, going with a hydraulic roller cam. looking at the comp extreme energy cam duration 292/300, lift 549/544. is it descent? will it have a good rumble? don't want it to idle like a truck lol.
Re: 493 build [Re: WV Runner] #2583948
11/27/18 11:40 PM
11/27/18 11:40 PM
AndyF Offline
AndyF  Offline
I think you're talking about the XR292HR-10 cam. That cam is 242/248 at 050 so it should be okay for street driving with a 500 inch engine. It will have a bit of a lope at idle but should have decent manifold vacuum. With headers and a 3 inch exhaust it would be fairly loud and have some rumble to it at idle.
Re: 493 build [Re: WV Runner] #2583960
11/27/18 11:53 PM
11/27/18 11:53 PM
WV
WV
Yes it's the xr292hr-10. been running 3" exhaust of years. its a street strip car, running manual brakes.
Re: 493 build [Re: WV Runner] #2584503
11/29/18 01:51 AM
11/29/18 01:51 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There is an interesting hydraulic roller that 440 Source has that is a custom grind from Comp Cams. It's a 571 lift and a little longer duration for 500" engines with good flowing heads. I was looking at a 588 for my 493 with EZ's but I may go with this 571 instead.
Duration at 50 is 252 In and 258 ex 110 lobe center
Gus beer
64 Plymouth Savoy
Dana 60
Re: 493 build [Re: WV Runner] #2584524
11/29/18 02:32 AM
11/29/18 02:32 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This is the Hughes cam I have with T&D 1.6 rockers.
Re: 493 build [Re: WV Runner] #2584603
11/29/18 11:23 AM
11/29/18 11:23 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
242/248 at fifty is more like what I'd use in a hot street 440. Small for a street/strip stroker IMO.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 493 build [Re: an8sec70cuda] #2585988
12/02/18 03:35 AM
12/02/18 03:35 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I agree....
I would add 10 degrees easy....
Re: 493 build [Re: WV Runner] #2585998
12/02/18 04:25 AM
12/02/18 04:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I've had a couple of friends have problems with the Comp hydraulic roller lifters. Go with the Howards lifters.
I use this cam and it works really well on the street:
https://www.summitracing.com/parts/hrs-723445-10
'63 Dodge 330
11.19 @ 121 mph
Re: 493 build [Re: GY3] #2586205
12/02/18 05:21 PM
12/02/18 05:21 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
What is the race weight of your car ?
Re: 493 build [Re: CSK] #2586229
12/02/18 06:18 PM
12/02/18 06:18 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
3,600 lbs.
Re: 493 build [Re: WV Runner] #2586869
12/04/18 01:43 AM
12/04/18 01:43 AM
USA
B3RE Offline
B3RE  Offline
USA
I used that cam in a similar 505 for a customer. Trick Flow 240 heads, 1.6, rockers, 10.1 CR, and Indys dual plane manifold. It sounded healthy, and made well over 600 hp on 91 pump premium.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: 493 build [Re: B3RE] #2586878
12/04/18 02:03 AM
12/04/18 02:03 AM
WV
WV
I’m glad to hear that!
