Re: 493 build
[Re: WV Runner]
#2584503
11/29/18 01:51 AM
11/29/18 01:51 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
There is an interesting hydraulic roller that 440 Source has that is a custom grind from Comp Cams. It's a 571 lift and a little longer duration for 500" engines with good flowing heads. I was looking at a 588 for my 493 with EZ's but I may go with this 571 instead. Duration at 50 is 252 In and 258 ex 110 lobe center Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: 493 build
[Re: WV Runner]
#2584524
11/29/18 02:32 AM
11/29/18 02:32 AM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
This is the Hughes cam I have with T&D 1.6 rockers.
Re: 493 build
[Re: WV Runner]
#2584603
11/29/18 11:23 AM
11/29/18 11:23 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
242/248 at fifty is more like what I'd use in a hot street 440. Small for a street/strip stroker IMO.
Re: 493 build
[Re: WV Runner]
#2585998
12/02/18 04:25 AM
12/02/18 04:25 AM
Posts: 4,693 Wichita
GY3
Wichita
I've had a couple of friends have problems with the Comp hydraulic roller lifters. Go with the Howards lifters. I use this cam and it works really well on the street: https://www.summitracing.com/parts/hrs-723445-10
Re: 493 build
[Re: GY3]
#2586205
12/02/18 05:21 PM
12/02/18 05:21 PM
CSK
Pattison Texas
What is the race weight of your car ?
Re: 493 build
[Re: CSK]
#2586229
12/02/18 06:18 PM
12/02/18 06:18 PM
GY3
Wichita
What is the race weight of your car ? 3,600 lbs.
Re: 493 build
[Re: WV Runner]
#2586869
12/04/18 01:43 AM
12/04/18 01:43 AM
Posts: 561 USA
B3RE
USA
I'm putting together a 493 stroker. 10.5:1 compression, indy ez heads, mopar single plane intake, going with a hydraulic roller cam. looking at the comp extreme energy cam duration 292/300, lift 549/544. is it descent? will it have a good rumble? don't want it to idle like a truck lol. I used that cam in a similar 505 for a customer. Trick Flow 240 heads, 1.6, rockers, 10.1 CR, and Indys dual plane manifold. It sounded healthy, and made well over 600 hp on 91 pump premium.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: 493 build
[Re: B3RE]
#2586878
12/04/18 02:03 AM
12/04/18 02:03 AM
Posts: 65 WV
WV Runner
WV
