02 2500 Cummins 2wd front wheel bearings . . . #2583675
11/27/18 02:22 PM
11/27/18 02:22 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
Just curious if anyone has changed/serviced front wheel bearings on a TWO WHEEL drive 2002 2500 Cummins ?? Are they a complete bolt in (if you replace everything), or you service the bearings and use new seal and spindle nut (seems like it is the nylok style one time use??) . . .
thanks,
Mark
Re: 02 2500 Cummins 2wd front wheel bearings . . . [Re: a12rag] #2583939
11/27/18 11:30 PM
11/27/18 11:30 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Around 97 all the lighter 2wd trucks started using a sealed front bearing hub that was replaced as a unit. I haven't worked on the "newer" stuff, but can't imagine they would not have the sealed bearing hub. Gene
Re: 02 2500 Cummins 2wd front wheel bearings . . . [Re: a12rag] #2584310
11/28/18 06:48 PM
11/28/18 06:48 PM
a12rag Offline OP
a12rag  Offline OP
Thanks . . .
Re: 02 2500 Cummins 2wd front wheel bearings . . . [Re: a12rag] #2584957
11/30/18 12:03 AM
11/30/18 12:03 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
My 2wd ‘03 1500 I replaced the hub and bearing as a one piece unit. I think yours can be bought as complete part or, bearing assembly separate. Take a look at RockAuto, for part info and pics.
Re: 02 2500 Cummins 2wd front wheel bearings . . . [Re: a12rag] #2586500
12/03/18 10:36 AM
12/03/18 10:36 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve replaced several. My 05 dodges and my 07. Comes as a complete package don’t get the really cheap ones. I’ve heard of short service life on those.
Re: 02 2500 Cummins 2wd front wheel bearings . . . [Re: a12rag] #2586586
12/03/18 01:47 PM
12/03/18 01:47 PM
a12rag Offline OP
a12rag  Offline OP
Thanks guys . . . I know mine are still ok, but just thinking ahead . . . I will probably own the truck another 20 years ! . . . LOL . . . I can see now that you can get the complete hub/bearing assembly . . . what about those "Nylok" nuts ?? I have not been able to find those - dealer only item ??
Re: 02 2500 Cummins 2wd front wheel bearings . . . [Re: a12rag] #2586729
12/03/18 07:37 PM
12/03/18 07:37 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Yes they are...I need to order one for my truck.
MOPAR number 6505007AA
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 02 2500 Cummins 2wd front wheel bearings . . . [Re: a12rag] #2586739
12/03/18 07:58 PM
12/03/18 07:58 PM
a12rag Offline OP
a12rag  Offline OP
Awesome . . . Thanks !!!
