Plate style throttle stops
#2583433
11/26/18 10:51 PM
11/26/18 10:51 PM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
I have on loan a Wiilys adjustable plate throttle stop, It does`t fit on my Indy intake as it is too high for my linkage. I am going to have the intake milled down an inch so i can use it. I have been using a Moroso bolt style stop for 10 years now and have been pretty successful with it. i currently slow the car down to 11.50 from 10.70s. I am hearing conflicting stories about how much the Willys stop can slow the car down. Before going thru milling the intake I am wondering if it will help me. I am mostly looking for more MPH as with my current setup my secondaries are barely opening thus killing my mph , i go 11.50 at 114 mph. Any body use one or an EZ plate system? that has some results? Thanks
Re: Plate style throttle stops
[Re: 11secdart]
#2583728
11/27/18 03:58 PM
11/27/18 03:58 PM
Posts: 11,635 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
People seem to like the Willys plate. I also see the EZ Plate system getting some good reviews. Slowing the car down nearly a full is quite a bit. I would call the Willys and EZ Plate people and see what they have to say. I see Willys will be at PRI. Great place to make contacts.
