68 B-body steering box removal. Help! #258333
03/18/09 07:50 PM
03/18/09 07:50 PM
Flint, MI
Gusteve Offline OP
I Love the Unicorn Song!!
Gusteve  Offline OP
Flint, MI
Hey all,
I'm trying to pull the steering box from my 68 charger. It looked like there were only two bolts holding it in. (1/2 inch 8 point - go figure)
I've got them out but the box refuses to budge. I've pried on it a little with a crow-bar, but before I went nuts with it I thought I'd ask if there is some secret that I'm missing.
Steering column shaft is disconnected, btw. It seems the steering gear housing is acting like its welded to the frame. Unless I'm an idiot and there's a third bolt that I can't find.
Thanks!
Re: 68 B-body steering box removal. Help! [Re: Gusteve] #258334
03/18/09 07:54 PM
03/18/09 07:54 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
yes there is 3 bolts.
Re: 68 B-body steering box removal. Help! [Re: Gusteve] #258335
03/18/09 07:57 PM
03/18/09 07:57 PM
Bethlehem Pa.
tinman68 Offline
tinman68  Offline
Bethlehem Pa.
I just looked at photo's of mine out of the car.
Yes 3 bolts. there's 1 looking down from front of car on left side of box. that's probilly the one.
Re: 68 B-body steering box removal. Help! [Re: blownzoom440] #258336
03/18/09 08:02 PM
03/18/09 08:02 PM
ELYRIA,OH
ELYRIA,OH
left side
Re: 68 B-body steering box removal. Help! [Re: blownzoom440] #258337
03/18/09 08:35 PM
03/18/09 08:35 PM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
OK - I am officially an idiot - didn't see the third bolt. (In my defense - the 70 factory manual I'm using didn't show a 3rd bolt either....)
It easily came loose after that. I thought I'd be a smart-butt and drop the box and the pitman arm as a unit, since i'll replace both. It didn't seem to want to come out so I removed the pittman. Still can't get the box out.
It looks like I'll have to drop my headers to get this stupid thing out!!!!! ARRRGGHHHH!
Is that normal!!!????? Last time I did this was on a 70 charger, and I seem to recall it was easy. (but no headers on that car).
Please someone give me a magic answer.....
Re: 68 B-body steering box removal. Help! [Re: Gusteve] #258338
03/18/09 08:52 PM
03/18/09 08:52 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I just replaced mine last month. I had to remove the drivers side header, z-bar, and starter. You might have to turn the wheels side to side to drop the header. It was a PITA. Oh, and make sure the car is jacked up high for clearance for the header to drop.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 68 B-body steering box removal. Help! [Re: Gusteve] #258339
03/18/09 08:57 PM
03/18/09 08:57 PM
ELYRIA,OH
ELYRIA,OH
well what 2 bolts did you take out?
all from 1 side?the pics show both sides 1 bolt on the left and 2 bolts on the right side.yes with headers you have to do some work like stated above.
Re: 68 B-body steering box removal. Help! [Re: blownzoom440] #258340
03/18/09 09:19 PM
03/18/09 09:19 PM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
Bolts were all from the same side. The 70 FSM I was using (from my previous car) only showed two, but once I stuck my head way back in the third one was obvious.
Sucks to drop the header. I had to drop the exhaust on the passenger side to get the torsion bar out, and if I have the entire exhaust on both sides dropped I might as well replace it!
One of those "while I'm doing X, I might as well do Y", and then I dump a bunch of cash. But hey, that's how this stuff goes, right?
Thanks for everyone's help.
