3.5" Exhaust Parts Source/Opinions Tail Pipes/Oval Tube/N20 #2583198
11/26/18 01:40 PM
11/26/18 01:40 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
We are getting ready to start fabbing up the drive shaft hoops and during that exercise I'd like to build the exhaust along the way.
I am contemplating using oval tubing from the headers, h-pipe, through the muffler and then back to round for the tail pipes (shock clearance) OR just routing the oval tubing right in front of the front leaf spring hanger w/ some 45 deg sections.
My last system of 15 years was 3" round, h-pipe, and routed the front of the spring hangers. I really liked it and rarely drop the 1/4 windows so it wasn't fumey in the car.
Also adding to the complexity is installing cut outs for nitrous use. I didn't figure that a full length exhaust is a good plan for a nitrous hit. Am I off base on this? My last exhaust system more or less burned the mufflers off like a barbecue and the thin metal rusted away at the welds. I'd like to avoid that considering the cost of materials.
Should I bite the bullet and go with 304 SS? I don't know much about MIG welding stainless.
Any thoughts are appreciated.
For vendors, it seems like a few places have oval tubing and such.
I like the idea of tail pipes for a more civil ride however the simplicity of a short exhaust system that divorces at the "H" is very appealing. I could have the old system off in ten minutes or less depending on how hot the car was.
Re: 3.5" Exhaust Parts Source/Opinions Tail Pipes/Oval Tube/N20 [Re: Jeremiah] #2583270
11/26/18 03:57 PM
11/26/18 03:57 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I got all my exhaust from these guys , but their being local to me swayed the decision.
They do a right nice X pipe.
They manufacture nearly everything in house and could probably do a build to order piece if you have a print or drawing with dimensions.
No oval tubing though.
http://heartthrobexhaust.com/
Re: 3.5" Exhaust Parts Source/Opinions Tail Pipes/Oval Tube/N20 [Re: Jeremiah] #2583283
11/26/18 04:23 PM
11/26/18 04:23 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Spintech has oval tubing. They even have oval x pipe setups. If you go oval tubing you have to go oversized to equal same flow as round pipe.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: 3.5" Exhaust Parts Source/Opinions Tail Pipes/Oval Tube/N20 [Re: steve660] #2583318
11/26/18 06:19 PM
11/26/18 06:19 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Interesting. I'll have to look for measurements. I didn't see any on Vibrant's site. Thanks for pointing me towards Spintech.
Re: 3.5" Exhaust Parts Source/Opinions Tail Pipes/Oval Tube/N20 [Re: Jeremiah] #2583319
11/26/18 06:25 PM
11/26/18 06:25 PM
an8sec70cuda Offline
I believe Kooks also offers oval tubing.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 3.5" Exhaust Parts Source/Opinions Tail Pipes/Oval Tube/N20 [Re: Jeremiah] #2583348
11/26/18 07:13 PM
11/26/18 07:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Aluminized tubing lasts very well. this exhaust system is 15 years old. I did have to recoat the headers as the tubing outlasted them.
Doug
Re: 3.5" Exhaust Parts Source/Opinions Tail Pipes/Oval Tube/N20 [Re: dvw] #2583392
11/26/18 08:47 PM
11/26/18 08:47 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Very nice system sir.
Re: 3.5" Exhaust Parts Source/Opinions Tail Pipes/Oval Tube/N20 [Re: Jeremiah] #2584481
11/29/18 01:10 AM
11/29/18 01:10 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
http://www.drgas.com/
never mind, he retired and closed up shop...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 3.5" Exhaust Parts Source/Opinions Tail Pipes/Oval Tube/N20 [Re: Jeremiah] #2584575
11/29/18 09:57 AM
11/29/18 09:57 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Racepartsolutions.com they might have it. Not sure
