Rear leave Spring identification for what application? #2582908
11/25/18 06:36 PM
11/25/18 06:36 PM
Plymouth, MI
HotRod20 Offline OP
HotRod20  Offline OP
Plymouth, MI
Hi everyone I have a set of rear springs with part # 2539 212.
This number is not in my 69 parts book,so may be earlier? I am asking if anyone with earlier parts books can identify the application for these spring. I have a set of two.
HR 20
Re: Rear leave Spring identification for what application? [Re: HotRod20] #2582916
11/25/18 06:51 PM
11/25/18 06:51 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 B-body - it's the STANDARD spring on a '69 V8 Charger & probably included with a 383 on Satellite and Coronet (non-performance non-SB/RR)
there is a 4-digit date & 5-digit vendor number also stamped on them - what's the date?
the part numbers in the Parts Catalogs are for "leaf spring assemblies" and differ from the numbers stamped on the bottom leaf
Re: Rear leave Spring identification for what application? [Re: 6bblgt] #2582952
11/25/18 07:49 PM
11/25/18 07:49 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted By 6bblgt
...the part numbers in the Parts Catalogs are for "leaf spring assemblies" and differ from the numbers stamped on the bottom leaf
What is the best way to find the spring application if all you have is the bottom leaf number? Reason I'm asking is I'm trying to verify a set of springs for a '69 big-block Dart (383) and couldn't find the number in the parts book. Don't have the number handy or I'd post it.
Re: Rear leave Spring identification for what application? [Re: 6PakBee] #2582967
11/25/18 08:10 PM
11/25/18 08:10 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I don't know if there are any list, but it would likely have to be reverse engineered from b'cast sheets & known examples.
xxxx 132 L&R '69 340 BH23
xxxx 575 L&R '69 225 LP23
xxxx 064 L&R '69 340 LM23/LS23
xxxx 056 L&R '69 383/440 LS23
Re: Rear leave Spring identification for what application? [Re: 6bblgt] #2582979
11/25/18 08:35 PM
11/25/18 08:35 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thank you!! up
