8-3/4 Rear End Housing Hardware #2582750
11/25/18 11:54 AM
11/25/18 11:54 AM
E
earlymopar Offline OP
E
Other than ordering from on-line sources, have any of you found a parts store that can provide the differential and axle flange studs for an 8-3/4" rear end housing? I'm trying to find a quick source if one exists otherwise I'll order from Dr. Diff.
Thanks,
- EM
Re: 8-3/4 Rear End Housing Hardware [Re: earlymopar] #2582758
11/25/18 12:20 PM
11/25/18 12:20 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I used ARP rounded nose, Ford 9" longer studs. This worked out well for the thicker Flange alum 8.75. I think arp also was the supplier on my axle flange studs, but not sure.
Re: 8-3/4 Rear End Housing Hardware [Re: jcc] #2582766
11/25/18 12:53 PM
11/25/18 12:53 PM
E
E
Thank you. That ought to open up the sources that have them too.
- EM
