70 Cuda 440-6 exhaust backfire #258258
03/18/09 05:10 PM
03/18/09 05:10 PM
Anonymous OP
Anonymous OP
OK guys got the cuda up and running really good with a minor snag. Have adjusted the carb using a vacuum gauge, set the timing but when I rev the engine to 2000 rpm's I get an occasional loud backfire out the tali pipe on the passanger side when I take my hand off the linkage. There is a black puff of smoke with the backfire. I am guessing fuel and am not sure but seems I may have an occasional miss on that side. New spark plugs and Taylor wires.
Re: 70 Cuda 440-6 exhaust backfire #258259
03/18/09 05:46 PM
03/18/09 05:46 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
usually fouled plug... or possibly incorrect plug wire routing/firing order... make sure the wires are seperated! and correctly placed first dan
Re: 70 Cuda 440-6 exhaust backfire [Re: ph23vo] #258260
03/18/09 05:49 PM
03/18/09 05:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah make sure all your plug wires are on reaaaal good. I like the snap-lock type myself.
