Re: Easy way to put fluid in Dana 60 with Alum cover?
[Re: 70satelliteguy]
#2582748
11/25/18 11:48 AM
11/25/18 11:48 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Parts stores have a small pump that works pertty well got mine at Advanced.My tranny is a pain to fill as the plug is close to floor.Only problem is tha cap for the pump is for a bigger cap hole.I just stick the hose in the bottle and pump away.Rocky
Chrysler Firepower
#2583156
11/26/18 11:33 AM
11/26/18 11:33 AM
crabman173
crabman173
The turbo Guru in Calif-- Banks-- has done extensive research on aftermarket aluminum covers --if it is flat inside it will kill your rear--the curved ditch in factory covers channels oil to the pinion--the alum covers that are flat inside do not allow proper oil path to pinion and they add air to the oil Check it out on Youtube or Bangshift etc The extent of the research was amazing--they add power to all kinds of trucks , campers etc so this was a natural area for them to look into--results are stunning--stock covers way better
#2583158
11/26/18 11:34 AM
11/26/18 11:34 AM
crabman173
crabman173
He tested every brand some were ok some were a disaster
#2583232
11/26/18 03:07 PM
11/26/18 03:07 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I wouldn't sweat gales research for an hot rod or drag race deal. The rear end doesn't get worked hard enough or long enough to see the issues Gale looked at. I would follow his research for my tow rig though.
68 Barracuda Formula S 340
