Re: Auto Transmission Speedo Gear/Housing - Question -
[Re: tinman68]
#258231
03/18/09 05:56 PM
03/18/09 05:56 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The year One housing is the version that accepts three different diameter pinions the smallest being 26 teeth, if the housing is marked 21-25 it is for the pinions with that tooth count and only those should be used in it.
I'm surprised you were even able to install it with the 36 tooth gear but the excessive side load from the oversized gear is probably the reason for the continued leak.
[Re: John_Kunkel]
#258233
03/18/09 06:06 PM
03/18/09 06:06 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
If you are using a larger tooth count than 25, you need the 'other' pinion adapter housing.
