Power steering Gearbox- later model #2581751
11/23/18 12:13 AM
11/23/18 12:13 AM
Colorado
67plymouthman Offline OP
Colorado
My buddy gave me a power steering gearbox that came out of a 75 a-body. He said it is tight and no leaks. If I use it in my 70 coronet, what do I need? Just a pitman and idler arm for a 74 Charger?
Re: Power steering Gearbox- later model [Re: 67plymouthman] #2581754
11/23/18 12:21 AM
11/23/18 12:21 AM
Andrewh Offline
Andrewh  Offline
just the pitman.
the idler should be the one for your car.
when I did the swap for my 65 coronet, all I changed out was the pitman arm and the hose piece to get the 74 and up to work.
Re: Power steering Gearbox- later model [Re: 67plymouthman] #2581755
11/23/18 12:28 AM
11/23/18 12:28 AM
Colorado
Colorado
I don't know why, but I always thought the pitman and idler had to be matched for the same year?
Re: Power steering Gearbox- later model [Re: 67plymouthman] #2581817
11/23/18 05:35 AM
11/23/18 05:35 AM
Andrewh Offline
Andrewh  Offline
I think you are thinking of stuff like fast ratio. I think in those cases they have to match.
but year to year the difference makes it impossible to match.
as I recall, in some cases how they bolt up differs so it wouldn't make sense.
Re: Power steering Gearbox- later model [Re: 67plymouthman] #2581867
11/23/18 11:51 AM
11/23/18 11:51 AM
Colorado
Colorado
Thanks! What hose piece did you buy-74 charger?
Re: Power steering Gearbox- later model [Re: 67plymouthman] #2581900
11/23/18 01:32 PM
11/23/18 01:32 PM
Andrewh Offline
Andrewh  Offline
I swaped it off my old one.
the pressure line fitting.
