Re: Motor Mounts [Re: 70charger512] #2581743
11/22/18 11:57 PM
11/22/18 11:57 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
So what I'm hearing is solid on both sides shouldn't be too much of a problem. I will probably do that, worst case I could easily swap the pass side back out if necessary.
Re: Motor Mounts [Re: 70charger512] #2581745
11/23/18 12:00 AM
11/23/18 12:00 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The 2 mounts serve different purposes, and are subject to opposite forces.
Boffin Emeritus
Re: Motor Mounts [Re: Cab_Burge] #2581746
11/23/18 12:00 AM
11/23/18 12:00 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
well the op ask for a STREET car that only see track ocasinaly !
and yes cheep hardware store chain and i bolts can strech !
now get a piece of G7 chain and equil eye bolt and have a small amount of movement that does not transmit vibrations to car from solid strap for a STREET car and have best of both worlds !
Re: Motor Mounts [Re: 70charger512] #2583167
11/26/18 12:24 PM
11/26/18 12:24 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I'd use solid mounts. The vibration doesn't bother me.
If you're worried about it, use stock mounts and get the torque strap from Schumacher Creative Services. I have one on my dad's six pack road runner and it works great.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Motor Mounts [Re: 70charger512] #2583365
11/26/18 07:53 PM
11/26/18 07:53 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I bought a set of the interlocking Poly mounts. They are expensive, so I just used one each on the drivers side mount of my two cars, and run good quality stock replacements on the passenger side.
