Holley Sniper linkage questions #2581163
11/21/18 05:10 PM
11/21/18 05:10 PM
Missouri
randavis Offline OP
randavis  Offline OP
Missouri
I am seriously considering the Sniper for my 74 Challenger with a 440 with a/t. Does anyone make an adaptor for the Sniper that is similar to the Holley carb adaptor that allows the factory linkage to be used? I have the carb adaptor from an old Holley. Will it work?
Thanks,
Randall Davis
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Holley Sniper linkage questions [Re: randavis] #2581669
11/22/18 08:18 PM
11/22/18 08:18 PM
Missouri
randavis Offline OP
randavis  Offline OP
Missouri
I know someone has put a Sniper on a 440. What did you use for accelerator and throttle pressure?
Re: Holley Sniper linkage questions [Re: randavis] #2581687
11/22/18 09:09 PM
11/22/18 09:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Read this:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2501485/1/super-sniper-install.html
Evidently the Sniper throttle body is wider and causes some linkage problems.
Re: Holley Sniper linkage questions [Re: randavis] #2581699
11/22/18 09:45 PM
11/22/18 09:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The SUPER Sniper is much wider, plain old Sniper, not so much.
Don't be the exception.
