1976 B-body brake booster in a 1972 B-body?
#2581640
11/22/18 06:46 PM
11/22/18 06:46 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
I'm not looking for factory correct just functionality.
A1 Cardone 50-3800 is pretty inexpensive but it's for a 1976-78 B-body and I want to install it in my 1972 B-body. Will it work? I'm 90% sure it will but I just wanted to check before I pulled the trigger.
No longer taking $h!t from anyone!
Re: 1976 B-body brake booster in a 1972 B-body?
[Re: DUFFMAN]
#2581793
11/23/18 02:39 AM
11/23/18 02:39 AM
Posts: 16,823 Between Houston & Galveston TX
SattyNoCar
Maybe the push rod is different? I installed a booster out of a mid '80's M-body in my wagon so I could run the aluminum MC without an adapter and the only issue I ran into was the hole diameter for the brake pedal shaft/pin was a different diameter. I just swapped out the push rod with the one originally from my wagon.
John
[Re: SattyNoCar]
#2581844
11/23/18 10:59 AM
11/23/18 10:59 AM
DUFFMAN
Slantytown
Maybe the push rod is different? I installed a booster out of a mid '80's M-body in my wagon so I could run the aluminum MC without an adapter and the only issue I ran into was the hole diameter for the brake pedal shaft/pin was a different diameter. I just swapped out the push rod with the one originally from my wagon. I'm looking at a loaded booster with the master already attached so the proper pin should be with it.
[Re: Jerry]
#2581845
11/23/18 11:00 AM
11/23/18 11:00 AM
DUFFMAN
Slantytown
if you get one for the 79 magnum or Cordoba its the same diameter and uses a 2 bolt master/\. I've swapped 3 cars like this works flawlessly
What I'm looking to buy is the same set-up used on a 1978 Magnum. It looks like the booster is the same just the master cylinder is different.
