Re: 7 Piece Piston Ring Set with Heptagonal Tensioner???
[Re: MadMopars]
#2581428
11/22/18 05:32 AM
11/22/18 05:32 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
That looks like a set of NHRA legal cheater rings back when you had to run the stock ring widths in the pistons, you could run a spacer in the groove to run a narrower ring or a gapless ring set. The hex ring looks like it is a spacer tensioner to run a narrow width low tension ring in a stock depth ring groove Maybe you can figure it out from the part number
[Re: Cab_Burge]
#2581689
11/22/18 09:11 PM
11/22/18 09:11 PM
Posts: 1,292 Tucson AZ,
MadMopars
Tucson AZ,
Cab, These came from that 413 I picked up so I don't know what brand or part number they are. Much to my surprise, they rebuilt this motor ages ago and never ran it. New pistons, bearings, etc. It also has a new Crower X31F cam in it. I'm thinking I'm going to clean everything up, put it together and give it a thrashing in one of the cars. That being said, any reason not to use these rings if I already have them? Where do these rings fall in relation to performance? Better than a standard set but not as good as a modern set?
[Re: MadMopars]
#2581698
11/22/18 09:42 PM
11/22/18 09:42 PM
Posts: 4,457 Washington
madscientist
Washington
Cab, These came from that 413 I picked up so I don't know what brand or part number they are. Much to my surprise, they rebuilt this motor ages ago and never ran it. New pistons, bearings, etc. It also has a new Crower X31F cam in it. I'm thinking I'm going to clean everything up, put it together and give it a thrashing in one of the cars. That being said, any reason not to use these rings if I already have them? Where do these rings fall in relation to performance? Better than a standard set but not as good as a modern set? No reason not to use them. As for those rings against a modern ring...a bunch of the power found in modern rings comes from piston groove geometry. It's sooooooo much better now that it's not even close. I'd run them and enjoy beating on it.
