Page 4 of 4 1 2 3 4
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2579661
11/17/18 09:03 PM
11/17/18 09:03 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have a picture of a Hurst RamRod in my Dart, but can't get it to resize to post. I am taller and have long arms, so the shifter sits a little farther ahead than it was intended to. I actually cut and rewelded the mounting bracket for it making it shorter and altered the shifter linkage length to make it fit a little better.
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2579666
11/17/18 09:21 PM
11/17/18 09:21 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
See if this works.
Re: Hurst V Gate shifter fitment [Re: Jeremiah] #2580766
11/20/18 08:47 PM
11/20/18 08:47 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
Does anyone know the Part# for the inline "Long" Shifter that would be most applicable to an 833 by chance? shruggy Thanks! -Trent
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2580773
11/20/18 09:03 PM
11/20/18 09:03 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Flipped it over for ya......
Re: Hurst V Gate shifter fitment [Re: MadMopars] #2581353
11/22/18 12:07 AM
11/22/18 12:07 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
They may be able to customize one for you but the one I used on an 833 came off a Jerico 4-speed box. I had to custom make the brackets and make my own tubular linkage with heim joints on the forward gears. I used a Hurst reverse rod from a supershifter.
I don't think they offer a "kit" to mount one to a Mopar box twocents
Gus beer
64 Plymouth Savoy
Dana 60
Page 4 of 4 1 2 3 4
