Page 3 of 4 1 2 3 4
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2578956
11/15/18 10:53 PM
11/15/18 10:53 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
bump
1970 EK2 T/A 727
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2579230
11/16/18 05:04 PM
11/16/18 05:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You seem to be focused on the length of the rod but, as you've stated, the trans lever is full back at WOT so the point is moot.
What you should be focused on is the "Start in 1 and floor it slap stick moves to 2nd by itself prematurely.".
Re: 70 340 6 pack kickdown rod too short [Re: John_Kunkel] #2580335
11/19/18 09:05 PM
11/19/18 09:05 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Checked mounts they are good. Today I reinstalled the rod after I tweaked it so it was the same length as a stock one. I was playing with the shifter handle and noticed that sometimes I couldn't get it to fully go into 1. So I drove it. When I would put it down in 1 once I got it to fully go I noticed the accelerator pedal was almost impossible to press. I brought it back and took a look under the hood and the shift linkage and kickdown rod linkage are interfering with each other. So this must be why when you floor it in 1 it automatically moves to 2 because the kickdown rod is pushing the shift selector to the next gear. How can I fix this?
1970 EK2 T/A 727
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2580347
11/19/18 09:48 PM
11/19/18 09:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Check the shift linkage for loose or missing plastic bushings, they're known to fall out.
Re: 70 340 6 pack kickdown rod too short [Re: John_Kunkel] #2580349
11/19/18 09:50 PM
11/19/18 09:50 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
has it but its not that color.
1970 EK2 T/A 727
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2580438
11/20/18 01:07 AM
11/20/18 01:07 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
color doesn't matter if the bushings are there and snug.
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2580685
11/20/18 05:02 PM
11/20/18 05:02 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
I think I may remove the anti-theft column lock rods and see if that helps
1970 EK2 T/A 727
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2581112
11/21/18 03:24 PM
11/21/18 03:24 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yours are probably white
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2581130
11/21/18 03:54 PM
11/21/18 03:54 PM
WA
tman Offline
tman  Offline
WA
Do you have a 2nd person to watch what is going on? Have someone push the kickdown linkage back and forth and see what is happening down below. Is it binding on something? After you "tweaked" it, now you can't push on the accelerator. Sounds like it got worse when you adjusted the rod. Almost sounds like the kickdown is not attached at the right place. Do you have a photo where the kickdown is attached to the transmission? The kickdown lever hitting the shift lever at transmission?
While car is on ramps or stands, put trans in 1st gear, move kickdown lever back and forth and see what is happening below. Use wheel chocks. Quick article about kickdown and different length levers.
https://www.hotrod.com/articles/the-lowdown-on-stock-torqueflite-kick-down-linkage/
Re: 70 340 6 pack kickdown rod too short [Re: tman] #2581143
11/21/18 04:32 PM
11/21/18 04:32 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
I believe the intereference of the column lock rear rod in the attached photo that is an anti-theft mechanism has been the issue with it automatically shifting from 1-2 the whole time. I had someone tell me to remove this rod and it would likely solve my issue.
1970 EK2 T/A 727
Re: 70 340 6 pack kickdown rod too short [Re: Morty426] #2581144
11/21/18 04:33 PM
11/21/18 04:33 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Yes
1970 EK2 T/A 727
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2581157
11/21/18 04:59 PM
11/21/18 04:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you remove the lock rod remember to set the lever at the bottom of the column or the ignition will lock.
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2581197
11/21/18 06:30 PM
11/21/18 06:30 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Are you sure you have the correct throttle pressure kick down lever attached at the valve body? There are different lengths. This would change the attaching point distance of the rod. Maybe it got switched out during a trans overhaul?
Doug
Re: 70 340 6 pack kickdown rod too short [Re: dvw] #2581207
11/21/18 06:50 PM
11/21/18 06:50 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Doug
I'm not sure of anything. How can I tell.
1970 EK2 T/A 727
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2581278
11/21/18 09:43 PM
11/21/18 09:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd have someone with a working set up measure theirs.
Doug
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2581305
11/21/18 10:48 PM
11/21/18 10:48 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Doug
Good Read with some pictures on the factory stuff so you can understand what your looking at with different length throttle levers and adjustment , never mind the Lokar cable setup mentioned in the article as that is an aftermarket set up
Click on link
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 70 340 6 pack kickdown rod too short [Re: stumpy] #2581897
11/23/18 01:15 PM
11/23/18 01:15 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Not sure I understand please explain.
1970 EK2 T/A 727
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2581954
11/23/18 03:54 PM
11/23/18 03:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The lock rod moves part of the column that allows the ignition to turn. It is an safety device the car from being started when in gear. Play with the lever and the ignition switch and you will see what I mean.
Re: 70 340 6 pack kickdown rod too short [Re: stumpy] #2582244
11/24/18 03:19 AM
11/24/18 03:19 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
If the lever on the lower column is down you can't get the key out. Ask me how I know this. whistling
Re: 70 340 6 pack kickdown rod too short [Re: f2502011] #2582316
11/24/18 01:04 PM
11/24/18 01:04 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Does the rod need to be all the way up or all the way up or all the way down for everything to function?
1970 EK2 T/A 727
Page 3 of 4 1 2 3 4
